Anyone have or know where I can get a vinyl 7 logo i can use to spray on my grille?
I want to use it to mask my grille mesh so needs to look like this
regards
[Edited on 13/5/16 by ste]
I'd suggest printing off that picture, re-scaling it to the size you want. If you need a vinyl template take it to your local signwriter place they will be able to cut out that shape, or provide you with an offcut to do it yourself.
Likewise, I'd go for a print out and cut one yourself. If you need help printing I can probably do it on A3 paper at work for you - U2U me if you need to.
I printed off a pic on paper, stuck it on some ali sheet and cut it out then fixed it to the grill
http://locostbuilders.co.uk/forum/4/viewthread.php?tid=67901
[Edited on 13.05.2016 by Humbug]
Thanks for the suggestions
How about cutting a stencil with laser cutter then overlaying on radiator and spraying?
I used a guy on ebay, only cost a few quid but was for something much smaller. http://stores.ebay.co.uk/N2Grafix
If you can get or make vector based image file for it most sticker places will cut it for a reasonable price.
Why go to all that trouble. Just stick a sheet of vinyl over the things, use a sharp modelling knife to cut around the template and job's done -
or am I missing something here?
Rich
