I'm desperate for a couple of M6 U-Nuts. Don't suppose anyone has a couple spare do they?
This type of thing;
Phil
I havent got any but can't you just make up a pair out of srtips of steel/ally and rivnuts?
- Jim
You can just buy them at your local hardware shop proboarly, here in the netherlands you can.
gr bram
Its a trim clip...
Halfrauds do them!
Usually called a speed nut or spire nut several different types exist
examples
http://www.amazon.com/b?ie=UTF8&node=16410081
[Edited on 9/10/08 by britishtrident]
Ive got some that look similar at home but called semi units, also have the corresponding hex head bolts that match. Let me know if you want some and ill dig out and post.
They don't appear to be speed nuts, spire nuts or trim clips. (According to my searching)
The ones I'm after have a threaded lug. Are these called lug nuts?
Phil
Like these
[Edited on 9-10-08 by Hellfire]
I know modern scooters use them for the bodywork so maybe a scootershop can even help you.
greetz,
Bram
Hi Phil
Think i have 2 or 3 5mm ones that came with my westfield rear lights but the lug is slightly crimped to stop the bolt coming undone.
Anygood???
Can get a pic if need be
Thanks for the offer Craig but I'm after M6's
Phil
Will have another rummage tomorrow
