Hi All,
I'm new to the forum and I have just started building a Mazda engined Vortx
I've came across a small issue when trial fitting the diff that I'm hoping somebody will be able to help me resolve so I can crack on with
the rest of the build.
Have others had to make any mountings/spacers between the two back diff mountings and the chassis? I'm presuming the front of the diff is solid
mounted? If I was to bolt the front up it would leave a substantial gap between the rear mounts and the chassis.
Hopefully this makes sense to anyone that's build a Mazda engined Vortx before but please see photo.
Any help would be much appreciated.
Thanks in advance
Tom
Yes you need a spacer. Some use the diff mount rubber bush thingys off the donor. I had a pair of alloy spacers turned up. Around 20mm thick from memory.
Can just see in this pic
Diffspacer
Thanks, that's exactly the answer I needed! I'll have my brother make a pair when he's back to work
[Edited on 6/2/16 by tom200490]
Here's mine ...
[Edited on 7/2/16 by clutch_kick]
Thank you both, managed to sort it this afternoon. The spacers will be with me in the next few days
Although I'm a little baffled as to why they should be needed in the first place. Why dont they just make the diff mount tubes longer??
I did think the same. I managed to find part of the mounts that were used on the donor (a rubber bushing with a metal cup) but I wasn't overly happy with using them. MNR did take diff measurements when I ordered the kit so perhaps some of the mx5 diffs are slightly taller..
The 1.6 and 1.8 diffs are slightly different size, about an inch. I wonder whether they've done the spacer thing so you can use either diff without it being out of position?
I will make a full build thread over the next few days, I've got 3 people working a full week on the car with me so I'm making a lot of
progress.
I don't suppose anyone has a photo of the mx5 bias valve in position so I can figure out these brake lines? Or even better a diagram of how they
are laid out? Most of my photos from the factory are saved to my work computer and I'd really prefer not to go in
I'm pretty certain I'm missing one line from the kit, as the supplied lines would give me no way of plumbing in the brake pressure switch in
the t-piece between the front shocks. I don't mind making up a new pipe, but would prefer to see how others are laid out.
Originally posted by tom200490
I will make a full build thread over the next few days, I've got 3 people working a full week on the car with me so I'm making a lot of progress.
I don't suppose anyone has a photo of the mx5 bias valve in position so I can figure out these brake lines? Or even better a diagram of how they are laid out? Most of my photos from the factory are saved to my work computer and I'd really prefer not to go in![]()
I'm pretty certain I'm missing one line from the kit, as the supplied lines would give me no way of plumbing in the brake pressure switch in the t-piece between the front shocks. I don't mind making up a new pipe, but would prefer to see how others are laid out.
Thankyou, I was hoping it would be like this. In other photos I've seen it screwed into a t-piece at the front. Perhaps they hadn't used the mx5 bias valve.
How did you (or anyone else reading) connect the pressure switch electronically? Does this have something to do with the connector hanging out of the
donor brake reservoir, or is this just fluid level. Is there a connector already within the donor mazda loom??
Stu
Hi Stu,
No, nothing to do with with the wire hanging out of the brake fluid reservoir, that is the low fluid warning switch. The pressure switch in question
replaces the contact switch that was originally engaged with the MX-5 brake pedal (so probably has a different connector style). This switch is to
activate the brake lights.
Some folk have had issues with the pressure brake switch, and have recommended a contact switch instead.
Mick
Ah, I see.
I've fabricated a bracket and used the original pedal switch so I guess I'll just keep the pressure swith as a back-up.
I am pretty sure( if you are re using the original loom) you will need to reconnect the fluid level sensor as that hooks into the handbrake warning
light. - Same light for "handbrake on" and "low brake fluid level".
Hope to build one of these myself (on the look out for an unfinished build!). How's it been so far? - Did you re use the MX5 pedals as the MNR
box is pricey.
[Edited on 13/7/16 by miskit]
Originally posted by miskit
Hope to build one of these myself (on the look out for an unfinished build!). How's it been so far? - Did you re use the MX5 pedals as the MNR box is pricey.
That's odd as MNR just priced me the pedal box at £325. Which I thought was a hefty chunk.
Am I right in thinking that the tub section (rear and sides) is the largest piece - if so roughly how long and wide is it?. I just saw that a chassis
fits neatly on a roof rack which got me thinking about putting the rest of a starter kit in my stripped out Picasso. I have shifted some big stuff in
it - 2m L x 1.4m W x .9m H is easily done any more needs careful looking at. If I do buy new it would save me a lot in van rental, fuel (600mile trip)
and ferry costs.
Putting the chassis on the roof rack is a lot of weight to put on top of an already tall car. I can give you the dimensions for the body tub sometime
this afternoon, but I would strongly recommend a van.
It's possible that earlier MX-5 based cars had a seperate pedal box, more in keeping with the Vortx RT+, but the later ones have it as part of
the chassis.
I would advise a van, as there is alot of bodywork (tub, arches, scuttle, bonnet) which take up rrom, you then have alot of parts. For ref I used a
VW crafter LWB, and although this was big the kit filled maybe 75% of it.
As for the company, my experience is similiar to Mick. it seems to be standard that they send out kits with parts missing (maybe due to availability
at time of supplying kit, i don;t know), i've also had a few incorrect parts. To be fair they have rectified when questioned and I usually
recieve things within a day or 2 (with the exception of exhuast, which took a while).
I can;t say if this is any better or worse than another manufacture as this is my first build, however I have seen things on here regarding other
manufactures that are similiar eperiences.
Stu
Tub is at least 10ft long, by about 3 wide at the back. I suppose you could mount/tape it to the chassis and put that the roof rack, but I'm not
sure I'd like to !
I filled a LWB van up too when I picked it up.
Mine did have a separate pedal box, but that was mid-2013
Do you need some spacers? I had some made but obviously never used.
75mm od with a 13mm hole in the centre. 20mm thick.
