I need your MS log files!
scudderfish - 23/8/11 at 08:19 AM
I'm making good progress with my MS logger for Android, but I'm somewhat limited by the fact I only have one ECU to test it against. I can knock together a simulator if I have a log file and it's associated MSQ file. Could you please email me any log files you don't mind sharing and if possible the MSQ file for your ECU. If you have modified the INI file from the stock ones that ship with MegaTune/TunerStudio could you attach that as well please? Send them on to dave.g.smith@gmail.com.
Thanks,
Dave
matt_gsxr - 23/8/11 at 10:23 AM
sent, sorry for the delay,
Matt
coyoteboy - 23/8/11 at 12:40 PM
Any particular requests? I've an MS1 extra "hires" and about 40 hours of logs somewhere!
scudderfish - 23/8/11 at 12:45 PM
I think 40 hours is a little long Anything from 30 seconds up really; the simulator just replays it on a loop. The more variants of MS I have access to, the better.
Regards,
Dave
daxtojeiro - 1/9/11 at 06:18 AM
Email me directly on philip.ringwood(at)ntlworld.com and I can send you as many as you like from all varients of MS ECUs as well as MS3 with EGT logs, VSS, etc, etc
Phil
ashg - 1/9/11 at 08:41 AM
i can do you some ms3 ones from a saab turbo motor if phil hasn't given you enough already
