fuel line opinion needed!!
jimbona2 - 24/5/08 at 01:41 PM
hi,
just want to check before I go do the whole lot, for the fuel line will this be okay?
thanks to the guy before me the prop shaft and panelling is all in, making it well hard to get these done.
please say if the fuel line is okay!
(the big black tube is the prop shaft!)
thanks,
[Edited on 24/5/08 by jimbona2] Rescued attachment DSCN1514.jpg
PAUL FISHER - 24/5/08 at 02:08 PM
You don't need to put them so close together,10cm apart should be fine,also I don't no if they are self tapping screws into the floor,or enginnering screws with nuts on the other side,but I would use rivets,to ensure they do not vibrate loose,as they are in the tunnel if they come loose you will not be able to get to them after you fit the tunnel panels.
tks - 24/5/08 at 02:39 PM
use rivets
and plan the electricity you aren't leaving much room left for the cables....
Tks
jimbona2 - 24/5/08 at 03:00 PM
thats the thing, i dont know what else will be going down there?
tks - 24/5/08 at 03:51 PM
fuel and electricity cant go close to each other. so drop the fuel in one corner with the brake hose and the electricity in the other.
just take out the shaft will make your life much easyer....
Tks
