how would i get one of these through iva just a matter of putting something over the buttons so they cant be pushed
As long as it looks permenant.
I used aluminium with leatherette over it on my VR2 and it passed sva.
why put something over the buttons?
dd2 is approved for road use and has been through sva/iva before.
I am assuming that you can navigate away from the speed?
If the speed stays put when you press them, then you don't need a cover
You know what assume does
There is an SVA/IVA setting in the menu option so that you can permanently hve the speed etc present on the dash.
So in answer to the OP - Just set it for IVA mode.
