anglia cvh in need of distributor after being converted to carb
jps21 - 2/4/13 at 11:03 AM
hi im in the last stages of the build with my anglia but i am needing a distributor to fit on the front of the block can anyone help?
Talon Motorsport - 2/4/13 at 11:26 AM
1600 or 1800 cvh?
jps21 - 2/4/13 at 11:29 AM
1600 cvh from a late sapphire
jps21 - 8/4/13 at 11:56 AM
sorry i have now found out that it is definatly a 1.8 from a late sierra
adithorp - 8/4/13 at 12:27 PM
Is it a distributor you need? The 1.8 Sierra CVH didn't have one as such; Just a rotor arm on the front of the camshaft sprocket and a dizzy cap attached to the cam belt cover.
mtechmatt - 9/4/13 at 01:17 PM
www.nodiz.co.uk
jps21 - 11/4/13 at 10:40 PM
adithorp this is the thing i am looking for doyou know where i could get one??
adithorp - 11/4/13 at 10:53 PM
I'd guess the rotor arm and dizzy cap should be available from a good motor factor. Probably not a stock item any more though so they'd have to order. The rotor clipped onto a bracket held by the cam pulley bolt. I'd imagine that's a Ford dealer only part. I assume you have the cast ally cam belt cover?
