Hi,
I'm planning on installing a second battery for the reverse motor as I have a small main battery.. Also do not want it to charge off the
alternator - I'll trickle charge at home.
I have planned that the earth will be the chassis such as normal, but I am wondering if this will have any affect on the other battery/electrics
generally and during operation?
Thanks,
James
It shouldn't have any effect, as unless you are actually reversing it will not have a complete circuit, are you running reverse lights off this
battery too or using a relay into the main battery?
Have you thought about the split charging systems caravaners use, I think it charges the second battery when the main battery is fully charged, so
only uses the alternator when not needed for the primary...
The reverse lights are off the main battery. I thought it best to run a separate battery to reduce the load on the alternator as it's a bec.
(Also easier for it to fall off after IVA if that were to happen).
The split charge system is something I have thought about, but kind of dismissed already.. no real reason why though!
I didn't think it would cause a problem as it isn't making a full circuit, but I'm no electrical expert! So the power from the battery
to the motor would return to the same battery as that's making a full circuit. Is that the correct train of thought?!
Thanks for the reply.
I originally did this with a split charge relay, but found the bike alternator charged the large battery fine, so just used the one battery.
Shouldn't make any diffetence to the alternator as on a bike alternator output isn't controlled the excess output goes to ground via the zenner anyway.
Why would you not want a reverse?
Why make it more complicated?
Larger battery charged off alternator.
Sod law is such that the one time you need reverse is the day after you forgot to charge it.
I'd be tempted to charge it. Then when you're reversing you'll have engine power and alternator volts plus battery volts. A battery voltage under high load will quickly sag.
The primary use will be track days, but I'll need to drive it there, hence the ease of removal and small main battery.
I'll take all of your advice and have a re think though.
Do bike engines have enough charging power when reversing to keep running?
I have this set up on my Triabusa. The reverse is off a totally separate circuit. I actually used a Golf buggy battery, large amps works a
treat. I just trickle charge it when the car is not in use.
Adam
Originally posted by Adam
I have this set up on my Triabusa. The reverse is off a totally separate circuit. I actually used a Golf buggy battery, large ampsworks a treat. I just trickle charge it when the car is not in use.
Adam
I have a friend who was running a car battering to run it. the amount of times he had to re charge his battery was crazy, so did some research and
came up with the golf buggy battery. Works a treat. I have mine earthed to the chassis. Theres no direct connection into the car/bike loom..
Totally separate circuit. Never failed me yet and been using quite a lot of late.
Adam
[Edited on 14/5/15 by Adam]
That's interesting - So they output the same power all the time? Does all that power get rectified?
For track usage, so youll remove it when you get there?
What happens if you spun off and need to use reverse, i cannot imagine the track owmers/event organisers being keen on having drivers on the track so
there can push their cars? Youll be sitting there waiting for marshalls to put you in track meanwhile your allocated track time is ticking away.
Still think that having a small but high capacity battery, not lead acid, lipo maybe, is a simpler and more reliable may even work out to be lighter.
