Hello all.
I’m looking for the part numbers of the following if any of you have or know a way of finding them out.
Brake servo Gasket and the gasket for the bulkhead panel that supports the brake servo.
These are on a 2005 Vauxhall Corsa or would I be better to just got o a local Vauxhall dealer?
The reason before anyone asks is water is leaking into the driver side passenger foot well of my sons car I’ve taken a good look and the only place I
can see that it is getting in is through one of these seals, if not both.
Any help advice greatly received.
If it's only stopping water ingress then virtually any silicone sealant should be up to the job - QED.
Cheers, Pewe10
You sure it's not the heater matrix leaking?
As above --- but unlikely to be the source the first thing I would do is check the scuttle drains are clear.
If it has a sunroof or AC also check the drains for those.
Hello.
Thanks for the replies.
I have checked the bulkhead drains they are clear.
I will check the heater matrix and AC drain.
It is a common problem with Corsa's leaking around the servo support panel, and water seems to be present on the foot pedals.
The gasket is just silcone sealant its a big job to do steering column and pedal box out takes about 5 to 6hrs check the scuttle drains are clear first...
how do I check the AC drain?
