Been offered a car back from insurance company that is cat n. What is required to put it back on the road damage is purely cosmetic. Does it need a
fresh mot as was moted until September.
Matty
[Edited on 20/2/19 by matty h]
It may need an Mot to get back on the road, and your insurance company will advise
Ive put a few Cat c a few years ago, back on the road, and only two required an MOT, one of them, and my current car was only 11 months and needed an
mot, and all for panel damage
steve
I've sorted out a few cat C (what the cat N use to be) right offs including the wife's volvo. tbh unless you are offered a dreadful amount
and the car is sold back to you for utter peanuts I'd not really recommend buying it back as the value will always take a very hefty knock being
recorded as a write off and it's something you will never be able to hide or remove.
I'd only recommend doing so if you intended on never selling the car and could not buy the equivalent with the offer from the insurance company.
Again another reason to have GAP insurance if you had finance on the car, something I wish we'd have had on the wife's car and I would never
hesitated to buy another car rather than buy back & repair hers.
I'd think very carefully about taking it back, it may seem a great deal but you may well be putting money into something that will never be worth
that much and if circumstances change and you need to sell it, you might be disappointed at it's value.
First catorgories - they used to be Cat A - destroy car, Cat B - break for parts only, Cat C - strucural damage and potentially costly to repair, Cat
D - cosmetic damage but beyond economic repair. The new catorgories - Cat A and B are unchanged, Cat S replaces Cat C and Cat N replaces Cat D.
They have graded your car as a Cat N so it should be an easy repair and some of them get written off for very little damage. I have bought and
repaired lots of them and if you intend to use them for a long time any reduced value from having Cat N recorded against the car will not affect you
much. Yes it will never fetch top book price and many traders will not allow part exchange with a car so recorded. I have never needed an MOT where
one already existed, only if it had expired and if you fix it properly then there is no reson to worry about getting an MOT anyway.
I have used such cars since the mid 1980's and would have no hesitation in doing so again
Can I also add, take and keep photos of the damage, and records of what is repaired etc.
I once enquired about a 2 year old car, to be told it was a write-off that had been repaired, but it was only scratches and a broken window. I
immediately backed out, as that damage would obviously NOT write a 2 year old car off. However, if they could have shown me pictures of the damage,
that would have reassured me. Plenty of little cars with CAT n running about, often a few bolt-on panels is all it takes on a 2-5K car. Which I still
don't get, but appears to be true.
Originally posted by ianhurley20
First catorgories - they used to be Cat A - destroy car, Cat B - break for parts only, Cat C - strucural damage and potentially costly to repair, Cat D - cosmetic damage but beyond economic repair.
I've sorted out a few cat C (what the cat N use to be) right offs including the wife's volvo. tbh unless you are offered a dreadful amount and the car is sold back to you for utter peanuts I'd not really recommend buying it back as the value will always take a very hefty knock being recorded as a write off and it's something you will never be able to hide or remove.
Cat C and D never represented the type or extent of damage, it was purely based on cost to repair vs value of the car e.g. cosmetic damage could be a Cat C on an old, low value car.
[Edited on 21/2/19 by MikeRJ]
Id always thought the same as Mike RJ. See the below from a confused.com guide to write offs:
Cat D cars are allowed to be repaired and put back on the road. The cost to repair the car is expected to be less than the car’s value before the
accident.
Cat C cars are similar to those in category D. The difference is that the repairs required to put them back on the road are expected to exceed their
pre-accident value.
Since a write-off is something which is sufficiently damaged/missing/impaired as to be financially nonviable for recovering (IIRC it's about 75%
of market value?) - I don't understand what the point in differentiating them would be. This one's damaged and not worth us recovering. This
one's also damaged, a little more, and not worth us recovering. The new system makes far more sense TBH.
As explained by the RAC website:
Category S (formerly Category C)
The new Category S means the vehicle has suffered structural damage.
This could include a bent or twisted chassis, or a crumple zone that has collapsed in a crash.
Category S damage is more than just cosmetic, therefore, and the vehicle will need to be professionally repaired.
Also, it won’t be safe to drive until then.
Read more
Category N (formerly Category D)
Vehicles graded accordingly haven’t sustained structural damage, so the issue may be cosmetic, or a problem with the electrics that isn’t economical to repair.
Don’t assume such vehicles are drivable, however; non-structural faults may include brakes, steering or other safety-related parts.
Originally posted by coyoteboy
If that was the case, surely C and D would be identical - if it had nothing to do with type or extent, both are just "uneconomical". My understading was always the same as ian's
Originally posted by Mark Allanson
I would like to clear up the confusion about categories
Cat A - Absolute total loss, burn out etc
Cat B - Severe damage where it would be unsafe for that chassis to go back onto the road, break only
Cat C - The repair costs exceeded the value of the car (no more, no less. A £90 car with car cracked headlamp costing £100 would be Cat C)
Cat D - The repair costs exceeded the value of the car less the salvage value. ( A £500 car with a £350 repair, but the Insurer would get £200 salvage, so it would cost them £300 to total loss rather than £350 to repair)
25 years as a bodyshop estimator/manager and Insurance Company Motor Assessor
As an aside I do find this whole "write off" thing a farce. My dad had a sierra which got hit hard enough to spin him onto some posts. Every
panel had damage, car was repaired yet there is no record on v5!
[Edited on 18/3/19 by Simon]
