Hi all, going to look / buy an 1999/2000 R1 next weekend so looking for tips of known problems to watch out for?
all have problems going backwards lol
Pretty bullet proof really, clutch release bearings / primary gear shaft bearings can get noisy if oil is neglected, noise goes away when you pull the
clutch.
Some tick like tapets from the top left - nowt to worry about, mines done it from new.
Head bearing wear, wheelies are so easy, but hard landings are even easier.
General signs of accident damage on a bike 10 years old, and botched wiring, some will have had more than one alarm fitted.
Alternator stators can fail, but unless you take a multimeter not easy to check, lights on, they should brighten when you lift off tickover, if they
dont suspect a charging fault....
cheers good advice hopefully I'll get a good one.
Jools
Be very careful on your first ride too! Even if you have had fast bikes before, when I went from a tuned zx6r to a R1 it felt like being shot out of a
gun and sitting on the bullet! Even a innocent sneeze can send the front straight up and you straight over the speed limit.
Also I have known the back to try to step out under heavy acceleration at this time of year even on dry roads, and as always check steering head
bearings as anyone who claims that they have never had the front up is almost certainly lying!
thanks for your warning Iam going from a cbr600 so I'll take it easy....
Jools
I know of a really nice R1 in Llanelli if you're still looking?
One of the orginal 1998 4XV Models.
Very close to standard condition - only mods are double bubble screen, crash bobins and Harris rear hugger.
150 bhp/170kg - no form of engine restriction in lower gears (as later R1's had). Massively fast.
29,000miles, taxed and MOT'd until next summer. Very good condition.
Ģ2500 ono
