Dear all,
OK, I've got this fantastic little gem of a 1999 reg, 2 stroke Suzuki AY50 scooter. 50CC that is - i.e. moped to you.
ANyway the oil pump has started leaking into the sump if it's left standing. (left standing in the garage for any length of time I mean -
obviously it gets left standing at the lights quite often but without any serious after effects... I digress... )
So day after day without use the oil pump drips steadily into the sump and eventually reaches the level of a tiny gap in the exhaust gasket (I
suppose) and a small pool of red 2 stroke oil appears on the garage floor.
Apart from the stain there's an embarrassing problem of huge volumes of thick creamy white smoke as the oil clears after starting.
Basically I have the choice of creating drifting clouds of smoke fogging up the front gardens near our house while it warms up OR laying a giant
white sausage of smoke trail away from the house and round the corner for the several hundred metres.
Is the oil pump serviceable? repairable?
Or should I just buy a new pump? Plus it looks very tricky to remove - anyone done it?
This is a serious question.
Genuine replies only please
ta
Dave
Can you not do away with the pump, and just mix in the 2 stroke oil with the petrol,
I did this on a Suzuki gt250 years ago to give me more power,
Not sure if its safe (in a reliability type of safe )
steve
Hmmm. Yes, good lateral thinking. I like it.
.... what happened to the GT250?
just a thought
we all did it by mixing it in a petrol can 25+ years ago in our fs1es...............just make sure its well mixed or you will be cleaning oil out of the carb..........happy days..........lol
fs1es - now they were REAL prestige machines
Still are I bet.
(even if they went beyond the threshold of hearing)
so many just blown to bits trying to go a bit faster ............lol
go out on an ap50 come home on the bus.............go out on a fs1e maybe end up in casualty...........lol
the later fsie also had oil pump
is this the time to admit to owning the custom version?
no photo's exist!
Maybe put a bike engine in it?
FS1Es were for losers!! Proper spotty teenagers had Suzuki AP50s with a seperate oil tank!
".... what happened to the GT250? "
Err it caught fire !!!!!!!!!!
was about a year after, after another mod of mine to get more fuel into the carbs involving a fuel tap each side of the tank, so one to each carb
it is quite scary doing 80+ with a fire just below your goolies !!!
You should be able to download a service manual online which will tell you if it can be serviced/ repaired and how to do this. It seems as simple as a gasket to me!
