Has anyone here sva'd a car with a Vauxhall XE engine? I'm struggling to get documentation to prove the age of my engine which i'll
need when i go for sva.
I tried vauxhall through various numbers and kept getting told they cannot provide a build date from the engine number only the VIN or reg number. I
then asked Martin Bell at KitCarWorkshop and they got a letter from haynes when svaing their fury. So I wrote to Haynes but today I got a letter back
saying that vauxhall "has not released build date information for engines" Perhaps Martin's engine was a 20XE rather than a C20XE which
mine is?
Can anyone ses a way around this? Other than buying an old enough car and either putting engine from old car into my phoenix, or putting my phoenix
engine number onto the v5 from the old car then changing it back after sva.
Thanks,
Chris
Have you got the VIN number???
I have a vauxhall program that looks them up.
Sorry. unsure if you meant you had it or not
I only bought an engine and therefore don't have a VIN number - hence the trouble..
Whats the engine number? and any idea what it came out of at all?
Ben
u2u sent.
ta,
Chris
I'd be interested to find the answer to this a I'll have the same problem. I also need to make sure i use the correct age block/engine
number as I have a few, I'm sure using an early engine number and cross referencing this with vauxhall's parts catalogue can provide a cut
off date for the engine as parts changed on a certain engine number. Whether you can get a letter from vauxhall to this effect is another thing.
NS Dev mentioned that you could get a letter from vauxhall, but that it costs 50 pounds?!
Ned.
I tried phoning the number that was posted on here - it was the same guy that was named in the post but he said he they couldn't trace the age
ned - I'm going to ask haynes if they can confirm different dates for a 20XE. I'll let you know what they say.
thanks chris, that'd be great.
Ned.
that would be great, cos that's just given me the same problem (although I can choose from a 20XE or a C20XE!!) as I thought ringing that chap at
Vauxhall would do the trick.
Thinking about it, plenty in the Westy owners club have rung him with just engine numbers and had no problems.
If all else fails is it not possible to obtain an old Astra or cavalier with a v5 and send it of to the dvla with details of the "new" engine number and therefore end up with a v5 with a date. Or am i tallking rubbish.
anybody had any Joy with Vauxhall for an age letter?
i checked the block i'm planning on using, so i might go and see if my local dealer/parts can help me out with a letter stating that the 20xe
engine code was only made until such and such a date..
Will be thurs before i get a chance. will let you know how i get on..
Ned.
That'd be great to know Ned, could use one too!
thinking about it, surely the haynes manual would state this information? will have a read of that later too. though whether the sva man will accept
it would be the issue imho.
Ned.
I have now found, amongst a pile of old papers, the logbook for the astra that my 20XE engine came out of. I think the owner left it in the car (which otherwise was missing interior and fit for scrap!) when I took it. I never sent it off, so can I just take this with me to the SVA test? It's not in my name but it has the engine number, VIN number, date of first reg and is declared new at first reg?
Having failed at getting anywhere with vauxhall last week I decided to email the same guy i phoned. It turns out that this week he can do it!!! But
the fee has gone up to an extortionate £75.
I have tried every other way of finding out (DVLA, VOSA, HPI, Local vauxhall place, Haynes) and no one else can help.
If you have a 20XE just phone haynes technical services (I spoke to a guy called Trevor Eastman 01963 440635). He can provide a letter giving what
years the engine was produced. As long as it doesn't overlap august 1995 you should be fine for sva.
If its a C20XE then you basically need the v5 or an expensive letter from Vauxhall. If you know the VIN number you might get somewhere with vauxhall
customer services as they can search on the VIN (or reg no i think)
So I either need to find another engine, collect it, clean it up, fit rod bolts, move over sump etc etc or pay the £75. SInce i want to get the car
running for the summer i think i've just got to cough up and save the hassle as much as it pains me to do it.
Chris
Heaven forbid anyone actually try it, but for a car for track only use surely you could restamp the engine number for an older 20xe code?
there are/have been plenty of blocks about with rods out the side, so finding one that won't ever be used again to 'borrow' the number
off shouldn't be too hard.
Ned.
If it was fro track only I wouldn't bother with SVA and i'd have no problem. I have considered it but my conscience is getting the better of me at the moment....
you could always cheat like i did.....shhhh. sorry i cant say but it worked
what, register the vauxhall engine number in the sierra v5, leave the spark plug cover off and hope they don't notice? if they do tell them its a
zetec transplant and hope they believe you or can't spot the difference?
Ned.
lol, i did think of that one ned but me and Mr.g thought it wouldnt work
