micklax
| posted on 8/4/10 at 01:04 PM |
Wishbones
Hi
I am looking for some help on wishbones for a Locost Race car. I need to know whether they must fit the spec as outlined in the book, or whether the
design is essentially 'free', as long as they fit the Cortina hubs and comply with the measurements as shown in the regulations.
I have acquired a set that fit the hubs and will fit the chassis (with some slight amendments to the pick up points).
Can anyone shed any light please?
Mick
blackie
| posted on 8/4/10 at 08:52 PM |
Hi Mick, you need to read the Locost Racing Regs;
Linky
As they describe the front suspension "limits of acceptability". The limits in the regs were added after all the drivers at the time
submitted the dimensions for their cars. So if you're making / buying wishbones per the book, you should be within the regs - it's just
to prevent people taking the p&^s
DB
micklax
| posted on 21/4/10 at 07:29 PM |
Wishbones - Pictures
Hi
Can anyone shed any light on these wishbones (Please have a look at the pics at http://mickslocostbuild.blogspot.com). They match the measurements
from the book, and will accept the Transit track rod end. My issue is with the size of the other end, which should have bushes fitted.
The tube at this point measures about 10mm (inside dia).
Can anyone help with any way in which they could be used, or any bushes which might fit?
TimC
| posted on 6/6/10 at 07:46 AM |
That is mighty odd...
Can't really think of an acceptable solution that doesn't involve replacing the tubes.
