stevegough
posted on 6/5/11 at 02:29 PM |
Adrian may be right there - the only IVA compatible rings are the half-round profile. There are ways around it - (if you pardon the pun) - a layer
of lovely hardboard to prevent the sphere touching the rings or some sort of rubber trim. I'm another one who's also very impressed by
the modification speed you are working at!![](/images//smilies/shocked.gif)
Luego Locost C20XE.
IVA passed Jan 28th 2011.
First drive Feb 10th 2011.
First PASA mad drive 26/7/11
Johneturbo
posted on 6/5/11 at 03:23 PM |
Car looks great
for the clocks how about some hard dense foam stuck on with double sided tape, it's what i used, but that was for SVA
![](/galpreviews/4sva1.jpg) ![Description](/gallery/4sva1.jpg) Description
locostbuyer83
posted on 6/5/11 at 03:32 PM |
Right, i've moved the clocks inward a bit to loose the edges... what do you think?
![](http://stulane.com/iva/311.jpg)
Davegtst
posted on 6/5/11 at 08:45 PM |
Wasn't there a problem a while ago with the steering wheel exemption zone? I though you had to have some kind of screen to mark the boundary
between interior and exterior. Might be a problem, are you planning to put an aeroscreen on?
locostbuyer83
posted on 6/5/11 at 10:27 PM |
Wasnt planning to. Not read anything in the manual about it?
Davegtst
posted on 7/5/11 at 02:07 PM |
I know it's not in the manual but i'm sure someone had a problem recently with it. Probably just a tester being a bit of a jobsworth.
locostbuyer83
posted on 7/5/11 at 08:02 PM |
Finished everything on the car today. Got the tracking to do on Monday and it's all done.
Thanks to everyone that commented on this thread.
JAMSTER
posted on 8/5/11 at 04:04 PM |
hope it all goes well tuesday. be good to see/hear how you get on as i'm not to far away from having an iva myself.
your car look's well
[Edited on 8/5/11 by JAMSTER]
gottabedone
posted on 8/5/11 at 04:35 PM |
Cracking looking car ![](/images//smilies/cool.gif)
Good luck!!
SteveWalker
posted on 8/5/11 at 05:17 PM |
You've mentioned having a warning light with the correct symbol on for the brake fluid and a plain red one for the handbrake and I think from
the pictures that your reservoir has a push to test button on top. Usually these days there is only the one light, so the handrake acts as a lamp
test. I'm sure there was some mention when IVA was coming in (but it might have been dropped) that the lamp should be able to be tested from the
driver's seat?
[Edited on 8/5/11 by SteveWalker]
big_wasa
posted on 8/5/11 at 05:34 PM |
Yep most people link it with the hand brake and pull that to test.
locostbuyer83
posted on 8/5/11 at 05:55 PM |
Ok, I'll sort that tomorrow. Thanks guys
CRAIGR
posted on 9/5/11 at 07:22 PM |
Good luck tomorrow Stu
locostbuyer83
posted on 9/5/11 at 07:59 PM |
Thanks mate. It's all on the trailer ready to go... I'll let u guys know how it goes.
Davegtst
posted on 9/5/11 at 10:25 PM |
Good luck, be sure to let us all know how you got on.
franky
posted on 10/5/11 at 01:58 PM |
hope it went well![](/images//smilies/bigsmile.gif)
locostbuyer83
posted on 10/5/11 at 02:47 PM |
http://www.locostbuilders.co.uk/viewthread.php?tid=155113
