markyb
posted on 7/11/08 at 09:32 PM |
r1 revs (koso clocks)
I have got everything wired up on my RX1N clocks except the rev counter and am unsure how to connect it to the engine.
I have done a search and some people have tapped into the wire coming out of the ecu but I dont know which one this is (I have the haynes scematics
but cant find it) .
Does anyone know what wire I should be tapping into or have alternative ideas.
thanks
PS engine is a 5PW
mangogrooveworkshop
posted on 7/11/08 at 09:36 PM |
its the wire from the ecu but you will need the exup servo from the 600 to avoid the fault code.
Kriss
posted on 8/11/08 at 01:01 PM |
mine is wired into one of the plugs, little jumpy though
Adam
posted on 8/11/08 at 04:04 PM |
Mines a 2000 R1 and i have mine wired to the ecu wire. No exup and verything seems fine, seems to be spot on when it went on the rollers.
Adam
markyb
posted on 8/11/08 at 04:18 PM |
thanks for the info - just need to work out what wire to use
