R Thurbin
posted on 26/1/04 at 01:38 PM |
Newbie
Hello all
I have a stupid newbie question that I am sure has been answered 1000 times before...
Being a novice mechanic, a limited budget and a willingness to learn I decided to rebuild the 55k mile xflow from the donor myself. Following the
Haynes book, the engine is now completely stripped down and is ready for machining / re-assembling. Please can you give me some advice on the
following issues:
Engine Rebore
The engine has covered 55k miles and I believe it to be genuine. No lip on the block, clean internals, no smoke ect. Do I want to get the thing
re-bored? ..or just fit new rings to the pistons? ..or put in new pistons & rings? Don't forget, budget is tight (as always!).
Head
Seeing as I am only going to race the thing when it is done I don't think I am going to bother with the unleaded conversion. Is this wise? Also,
do I want to get the head checked for cracks / warping or *should* it be OK? Is there a *low cost* way to check?
Con Rod Bolts
I have seen the advice from D Beddows and thanks for that. How about the conrods themselves? ..or is it just the bolts that are worth updating?
Timing Chain
The Haynes manual talks about fitting double sprocket and chains. Is this allowed? ..is it worth it?
Valves
The Haynes manual talks about fitting double springs to the valves... again is this allowed?
Carbs
What kind of price should I pay for a second hand one? ..with / without jets ect...
Oil & Water Pumps
Do I stick with the standard or uprate?
Fuel Pumps
Thanks to Hugh Paterson for his advise.
Distributor
Thanks to procomp for his advise.
Cam
A hot topic at the moment.. I will be making sure the one I get is stamped!
Have I missed anything?
Any help greatly appreciated.
See you all at Mallory! (sadly only as a interested spectator)
Richard T.
GParkes
posted on 26/1/04 at 01:54 PM |
I’ll try and give a view on some of your q’s.
If the original bores are ok and the budget is tight I would probably go for new rings. A rebore up to the max +90 will give more power, but if you
are starting out this can always be done later. Just changing the rings will save quite a bit of money.
As for con-rods, you have to use the original ford items and can’t change for stronger high performance ones. As for bolts ARP whilst very good are
also expensive, I was advised (by Burtons!) that the ones fitted to the lotus twincam engine will fit a crossflow and are built to take slightly
higher loads up to about 7,000rpm, does anyone else have a view on this? as they are about half the price.
I have fitted a new water pump and kept the original one as a spare, and have also fitted a high pressure/capacity oil pump. I think these are better
if you use an oil cooler, and the book recommended an uprated pump.
I hope that helps answer some of your questions.
Gavin
