Author: Subject: What to take to SVA?
bassett
posted on 29/3/09 at 06:26 PM Reply With Quote
Hi is there anything i need to take to sva other than myself and the car?
Ive packed in a second car all my tools, trim, glue, food etc just wondering if we need much else like photos, reciepts, documents?
Adam
l0rd
posted on 29/3/09 at 06:30 PM Reply With Quote
Define all my tools
tegwin
Take a shotgun.... shoot the silly tart!
We took a folder with a few build photos in to help explain the bits you couldnt physically see....
You need some paperwork to prove engine age.....
And anytyhing else you think might help prove you have met all the requirements...
its a fools game... Enjoy
www.verticalhorizonsmedia.tv
stevem2727
posted on 29/3/09 at 06:33 PM Reply With Quote
sva
I had my test 2 weeks ago the only paperwork i needed was the v5 of the doner car,didnt get asked for anything else,just take loads of tools and trim for those radius edges!!!Good luck
omega0684
posted on 29/3/09 at 06:41 PM Reply With Quote
as much of your garage as you can legally fit in the back of your support car!
FEZ1025
posted on 29/3/09 at 06:47 PM Reply With Quote
If you fuel lines aren't marked fuel, then documentary evidence they are designed for fuel, same applies if you have rubber pipe from M/C to reservoir may have to prove they are suitable for brake fluid. But engine age is the big one.
Alan...
Pdlewis
posted on 29/3/09 at 07:31 PM Reply With Quote
Good luck Adam. Just tools and some spare trim it think.
If you pass the emmisions could you send me a copy of your map file?
Paul
Build Photo Album
Updated 05/02/2009
lotusmadandy
posted on 29/3/09 at 07:53 PM Reply With Quote
Good luck Adam,i took most of my
garage but only used a screwdriver
and cable tie.Still failed though.
bassett
posted on 29/3/09 at 08:13 PM Reply With Quote
Cheers guys thanks for the reminder as i do need brake hose document and the r1 haynes manual to show engine age. Tools are everything to build the car other than compressor which only got used to dust the car off anyway.
Paul yeah il send you a map - il probably post some pics if it passes just remind me with a u2u.
thanks again
Adam
