Author: Subject: pinto 2.1 weber jet sizes
stevem2727
posted on 7/5/09 at 07:54 PM Reply With Quote
Starting to get a bit annoyed now with the rough running of my car.It does not want to rev past 2750 rpm without pumping the throttle pedal continuously.I have checked fuel pressure which is anything upto 4.5 psi using the regulator.All the timing is spot on including cam belt.Tappets have been adjusted.I had the webers off today,cleaned them all and blew all the jets out,but still the same.Does anyone no what size the jets should be for this engine(mains are 145 at mo)or a carb specialist in the surrey area.Thanks guys
tomgregory2000
posted on 7/5/09 at 08:04 PM Reply With Quote
Are your pump jets working?
When you press the throttle there should be a linkage that goes to underneath the carb, that little assembly will squirt fuel direct down the inlet, if you are having to pump the pedal it sounds like this it not working.
Just my 2pence
cadebytiger
posted on 7/5/09 at 08:57 PM Reply With Quote
my jetting on 2.1 pinto with 45s and a fast road cam is:
Starter Jets F985
Air corrector 180
Emulsion tube F16
Main jet 155
Idle jet 55F9
pump jets 45
Main venturi 36mm
aux venturi 4.5
Hope this helps
Rupert
cadebytiger
posted on 7/5/09 at 09:03 PM Reply With Quote
PS.... Think my main jets are a bit big...
stevem2727
posted on 7/5/09 at 09:32 PM Reply With Quote
Thats great advise thanks very much guys
