Author: Subject: rough running pinto distributer reqd.
stevem2727
posted on 22/5/09 at 07:54 PM Reply With Quote
Hi all,real long on going problem with my mk.Took the car to Austec in crawley today for a rolling road tune/ diagnostic check.After 3 weeks on the road 150 miles and 3 weeks of thinking i had a fuel problem,he came to the conclusion the fault is with the ignition system.For those who havnt read of the problem,my car will not rev over 2750 revs it just goes flat and holds back,pumping the throttle pedal then increases the revs.Fuel pressure checked,carbs stripped and cleaned,tappetts done,cam belt timing done,timing done,carbs balanced and mixture set.Paul at Austec plugged some machine onto the car and it showed that under load number 4 cylinder was not firing and the others were all over the place.We tried new plugs,ht leads and a coil but none helped,so only thing left is a distributer.my car has electronic ignition and was hoping someone might have a spare in their garage for sale or borrow to see if it is the problem before spending £250 for a new ignition system,thanks guys.
posted on 22/5/09 at 08:01 PM Reply With Quote
Might be better if this was posted in the wanted section?
smac
posted on 22/5/09 at 08:07 PM Reply With Quote
If your gonna spend any big money buy a megajolt instead. It will be infinitely superior and transferable to your next engine. ( and a lot less than £250.00)
r1_pete
posted on 22/5/09 at 08:09 PM Reply With Quote
Check the side movement at the top of the dizzy shaft, if its ok a cap and rotor should cure your problem.
If there is movement yes a new distributor or bearings are needed.
jacko
Which type of dizzy have you
Vacuum /non vacuum ?
have you any photos of what you have
dose the module have 6 wires ?
stevem2727
posted on 22/5/09 at 08:43 PM Reply With Quote
It is a ford dissy that looks like it used to have points.I only have 2 wires coming from it one going to the possitive side of the coil and one to negative.
stevem2727
posted on 22/5/09 at 08:44 PM Reply With Quote
Sorry no vacum,running twin weber 45s
