Author: Subject: 1.8 zetec whats it worth & whats need to transplant
M$RK_VXRD
posted on 17/6/09 at 06:48 PM Reply With Quote
im in the process of buying a R reg escorte 1.8 GTi with zetec engine
is it worth the £80 im going to pay?
what would i need to do to fit the type 9 box off the pinto?
also their anyone in south yorkshire area with car transporter that could collect it for me cheap its only in west yorks!
posted on 17/6/09 at 07:11 PM Reply With Quote
Well worth £80 for the lot... the type 9 will bolt straight up, only thing needed is a Capri release bearing.
1.8 out of an Escort is the most straightforward RWD zetec. Short sump, water pump goes the right way etc..
Going to Newark? Hunt me out and Ill show you how easy it is.
M$RK_VXRD
posted on 17/6/09 at 07:35 PM Reply With Quote
yeah i will be going down on saturday if its not raining are you their all weekend?
thanx
Steve G
posted on 17/6/09 at 07:43 PM Reply With Quote
Being the GTi it will have the higher power cams like the 2L version has wont it. Well worth the £80 as said
Slater
posted on 17/6/09 at 08:23 PM Reply With Quote
You will also need a spigot bearing. About £5 off ebay.
Ford part number is FINIS code 1554973
The clutch release bearing you will need is CT 133.
Also the starter motor from a CVH Sierra.
[Edited on 17/6/09 by Slater]
Danozeman
posted on 17/6/09 at 08:47 PM Reply With Quote
That is the best choice and a bargain aswell.
Sell off the interior et and itl fund some of your build.
Dan
UncleFista
posted on 17/6/09 at 09:12 PM Reply With Quote
I have the same engine (albeit out of an Orion Si) waiting to go in my car
I got a bargain, the engine was only £40, but £80 for just the engine is a good price. As you've the whole car you could just stick some of the bits you don't need on ebay and make some cash back.
I sold the inlet manifold (ally with HO cast into it) on ebay and made £50-odd
If you don't want the hassle, couldn't you remove the engine fro the donor and leave the carcass on the seller's drive for him to dispose of and make a few quid ? Might be cheaper than paying for a recovery truck.
[Edited on 17/6/09 by UncleFista]
Tony Bond / UncleFista
HOL
posted on 18/6/09 at 08:35 AM Reply With Quote
Unfortunately not
The 'GTI' had the same 115bhp engine, ecu and throttle body as the 1.8LX etc, from 1997 onward.
Only the XR3I and SI came in 130bhp derivatives to 1998.
Ive had both as road cars.
M$RK_VXRD
posted on 18/6/09 at 04:04 PM Reply With Quote
thanx for the info lads!
i think im going have to remove the engine at his as he is now saying he wants £100 4 for the hole car or £80 for the engine!
so should i remove with the engine i.e to get it running ecu, etc? sorry im am a little bit of a noobie to all this
so if theres anyone handy with a spanner local to me and willing to give a hand to remove it for some beer tokens please let me know
[Edited on 18/6/09 by M$RK_VXRD]
