Author: Subject: Zetec Engine and ECU How are they compatible ?
Scoobythedog
posted on 14/7/09 at 10:36 PM Reply With Quote
I've got a 2 litre Zetec engine, originally from a 2001 mondeo, I'm pretty sure the cylinder head gasket or head is gone,
It seems easier to just by a new engine and swap it, rather than fix it. How do I now which engine will be compatible with my current ECU (which is standard ford)
Is there an easy way to find out before I buy the engine ?
CHeers
austin man
posted on 14/7/09 at 10:49 PM Reply With Quote
dont thik you will have any problems with the ECU I think this is only problematic if you dont have the coded ignition key. Obviously go for a black top if thats what youve got not a silvertop are ou running the blacktop
big_wasa
posted on 15/7/09 at 04:01 PM Reply With Quote
As long as its the same type of engine it will be fine.
