r1_manx
posted on 7/12/09 at 11:33 AM |
AIS removal advice
Hey guys,
I am looking to remove the AIS system on my 2003 R1 engine. How have other people on here gone about this? Any advice and pics is appreciated.
If im not in action, im in traction!
bassett
posted on 7/12/09 at 01:05 PM |
On mine i removed all of it and then used bolts to block the four outlets by the exhaust. Should be some pics in my build(see address below) around
dec- feb sort of time.
Adam
aitch
posted on 7/12/09 at 08:32 PM |
im guessing this is the same as the pair system on a hayabusa, providing air into the exhaust for emissions,?
on the hayabusa we just remove the lot and blanc off the holes on manifold, in fact i cut off the pipes about 10mm from the plates that bolt to
manifold crimped and welded them up
aitch
r1_manx
posted on 8/12/09 at 09:41 AM |
Cheers for the info guys, I think i'll try the crimp and weld method. The hyabusa is slightly different in design I think but the same
principle where it's intended to reduce emissions.
r1_manx
posted on 26/12/09 at 11:45 AM |
Got round to looking at the AIS system on my R1...they are now cut, crimped and welded up, it's definitely an easy solution to the problem
without having to fork out for a AIS removal kit.
See pic:
http://www.flickr.com/photos/r1manx/4211000793/in/photostream/
