scutter
posted on 3/5/10 at 05:07 PM |
2.0 blacktop zetec
After more upgradeitus, I have my 1996 2.0L blacktop for sale.
Spec's are as follows;
as said 96 2.0L
Chopped two part sump
Gas flowed head, all valve seats machine cut by a fellow who used to do formula ford Xflows, Had 2 new valves.
ARP big end bearings to increase rev limit, i've been running a 7200 limit, but should be safe for 7600rpm.
There are no extras with the exception of the coilpack. The oil has been changed every 4000miles or 6 months which every came first.
Pic of sump chop before block prep.
phase 3 sump
The engine is sweet and sounds great, Facebook clip
All this can be your for £275, but open to sensiable offers.
Check out my 'WWW' below for more pics.
ATB Dan.
[Edited on 3/5/10 by scutter]
scutter
posted on 4/5/10 at 11:24 AM |
176 views, no one? Open to offers before going on the bay.
ATB Dan.
Wumps
posted on 4/5/10 at 12:16 PM |
Hi, the vid does not work - i think it is due to privacy settings? So are you keeping all the ancillaries? manifolds? What gbox did you use with this,
type 9 with cct133 bearing?
scutter
posted on 4/5/10 at 05:51 PM |
yes it ran a type 9 1800 flywheel and cct133 bearing.
There is nothing else with the engine bar a coil pack and leads, some sensors.
ATB Dan.
[Edited on 4/5/10 by scutter]
AndyW
posted on 5/5/10 at 05:48 PM |
in 3 or 4 months I would have snapped this up, always the way!!
Wumps
posted on 5/5/10 at 06:10 PM |
Hi, where abouts are you? I'm just trying to work out what else i'll need to get up and running to see if its within a feasible budget. I
already have the type9 box with the correct bearing.
edit: also what is the approx mileage?
[Edited on 5/5/10 by Wumps]
scutter
posted on 5/5/10 at 08:42 PM |
You'll need the following;
Flywheel 1800 preferably
Induction, Carbs&Megajolt or throttle bodies and ECU
Exhaust system
Starter
Alt.
If it helps your budget i'll drop the price to £225. Mileage, it had 96k when it went into the kit and i've added another 7k.
Located at Carterton, West Oxfordshire.
ATB Dan.
[Edited on 5/5/10 by scutter]
posted on 5/5/10 at 08:45 PM |
Asking too much mate.
And, why has a silvertop got a blacktop sump?
Wumps
posted on 5/5/10 at 08:50 PM |
Thanks for the offer and further info but mileage too high really sorry
scutter
Thanks very much! It's a blacktop 1998 vintage, i know as i've shimmed all 16 valves.
Sorry that came out wrong and i've listed the engine age wrong to start with
ATB Dan.
posted on 5/5/10 at 08:55 PM |
No problems with high mileage zetecs, Fast Ford stripped one with 178K on it and there was no wear.
Sorry Scutter, I was confused as it looks like it has a silvertop cam cover and blacktops didn't appear until 98'
scutter
posted on 5/5/10 at 08:57 PM |
No, I just smoothed a phase one blacktop ali cover and painted it.
ATB Dan.
scutter
posted on 6/5/10 at 06:16 PM |
SOLD pending payment and collection. Many thanks Dan.
