josh
posted on 5/6/10 at 05:25 PM |
Dont be tight!!!
Well after weeks of pi$$ing around, i've finally started my chassis
Nice solid base to work from, all painted white. plan drawn out, loads of steel. away we go!
started off fine, got the main floorpan shape down and tacked, then for some unknown reason my welder decides he's had enough, throws a strop
and stops dead!!!!!!!!!
Pulled apart, cleaned, checked still no life.
Now in for another few agonising weeks till the bank balance is in the black then shiny new welder:
That'll teach me to be a tihgt @r$e
TODAYS TOP TIP:
Dont skimp on the important things (or borrow of a so called mate!) Buy quality once, not sh!!!tE twice.
RichardK
posted on 5/6/10 at 05:27 PM |
Did you see this? dunno how we could get it to you though?
Linky
Rich
Gallery updated 11/01/2011
josh
posted on 5/6/10 at 05:34 PM |
bit of a trek...i'll keep a beady eye on it
See if i cant persuade the wife to a journey up country!!!
Stuart_B
posted on 5/6/10 at 05:53 PM |
hi josh, bad luck on the welder,
i notice that you are around the conor from me, well clacton to colchester is not that far,
may have to net up and have a chat.
stu
josh
posted on 5/6/10 at 09:15 PM |
Yeah mate definatly.
give me a chance to pick your brain on components ect.
hughpinder
posted on 7/6/10 at 12:46 PM |
I used to have a SIP weld that would cut out in hot weather if you left it switched on and in the direct sun - it used to run again, but took about 3
hours to cool enough to start again
May be worth checking if its going again a few hours later, and if it is - make sure its in the shade when you're working
Regards
Hugh
flibble
posted on 7/6/10 at 12:59 PM |
Worth keeping an eye on:
Clarke 160en
1 Day left and only at £20, you might be lucky and get it fot £30, then again, it may well rocket up to £200 in the last 10 seconds, a'la Ebay
sniping
josh
posted on 7/6/10 at 06:07 PM |
Must of cut out with the heat, tried it to day worked but farting and spluttering with no decent welds
Got new regulator ordered see if that improves it. The mate i got it of said it hadn't been used in a while........looks like not loooked after
either. If this doesn't work gonna have to bite the bullet and stick it on the plastic!!!! Itching to get that chassis finished!
