Author: Subject: leg room
scoobydooby914
posted on 29/7/10 at 06:35 AM Reply With Quote
leg room
my mk indy blade is fitted with grp seats and the drivers one is on a sliding rail, i think. i cant get it to move but as it will only be me driving, is it worth removing the rail and just putting the seat where i want it straight into the car, as i could do with a tiny bit more leg room
designer
posted on 29/7/10 at 06:39 AM Reply With Quote
I think most people have them fixed for themselves.
scoobydooby914
posted on 29/7/10 at 07:10 AM Reply With Quote
Will there just be nuts under the car and the bolts are captive
designer
posted on 29/7/10 at 07:26 AM Reply With Quote
Probably, mine are.
Dangle_kt
posted on 29/7/10 at 07:44 AM Reply With Quote
yeah, it depends on the rails though - mine isn't captive in the rail, and I need to slide the seat forward to get at the back ones.
My mrs doesn't want to drive it, so I might take my rail off over winter.
iscmatt
Contributor
Posts 1929
Registered 30/3/06
Location York
Member Is Offline
Photo Archive Go!
Building: - BUILT - 2.0 pinto indy, Kent Cam, zzr1100 carbs
posted on 29/7/10 at 08:41 AM Reply With Quote
I would say do what you want. Thats why you have a kit car right? so that it is the way that you want it!
ReMan
posted on 29/7/10 at 02:18 PM Reply With Quote
Is there a gap between the seat back and the panel behind the seats?
If so then whatever is holding it vcan be removed and it re-fitted wherever you want it
