supercat
posted on 11/8/10 at 11:17 AM |
Maxi Balljoint at Motor Factors
Hi, Does anyone know the QH or alike number I can give to my local Motor Factors for the Maxi Balljoints?
James
Mark Allanson
posted on 11/8/10 at 11:24 AM |
If they cannot look it up themselves, go elsewhere.
A bit like going to the butchers for something for dinner, and the butcher asking you what chops look like!
supercat
posted on 11/8/10 at 11:29 AM |
Yes I know what you mean, just hoping to avoid going further afield......
breezy
posted on 11/8/10 at 11:30 AM |
Copied and pasted this from a reply I had earlier this week....although not sure they may still have a Maxi Listed....
They have lots of their information downloadable from the web now. http://www9.qha.com/uk/technical/catalogues.htm and
http://www9.qha.com/uk/technical/qhcatalogues.htm Hopefully that's got the information you need.
You've turned into your dad the day you put aside a thin piece of
wood specifically to stir paint with.
irvined
posted on 11/8/10 at 11:38 AM |
The QH Website has a tool you can download, you can search by car, and it lists the QH Part numbers, and all the other alternative numbers, oem, etc.
You can also search by OE partnumber, qh number etc...
Very useful.
http://irvined.blogspot.com
procomp
posted on 11/8/10 at 12:28 PM |
Hi
Most motor factors will not have a catalogue that will go that far back in time.
QSJ602S.
Cheers Matt
Edit to say. Use a QH if you can they are constructed in a different way IE as OE not like the cheap ones that are pressed in from above.
[Edited on 11/8/10 by procomp]
supercat
posted on 11/8/10 at 01:34 PM |
Thanks Matt.
James
