Author: Subject: Printing file names
Paul (Notts)
posted on 11/9/10 at 10:20 AM Reply With Quote
Printing file names
Quick Question...
How do I print a list of the file names that are in a folder?
I can see them all but can't find out how to print a list of them .
Paul
posted on 11/9/10 at 10:26 AM Reply With Quote
I have used this in the past
http://www.karenware.com/powertools/ptdirprn.asp
imp paul
posted on 11/9/10 at 10:27 AM Reply With Quote
you could press ctrl and a to highlight and then right click mouse then press print works for me hope this helps mate or ctrl and a copy and paste in to note pad and then print
[Edited on 11/9/10 by imp paul]
Rek
posted on 11/9/10 at 10:36 AM Reply With Quote
old school
open a command prompt
dir > atextfile.txt
notepad atextfile.txt
zilspeed
posted on 11/9/10 at 11:34 AM Reply With Quote
I usually do a screen grab, then copy the contents into paint and select the bit I want to keep by cropping.
In my case, I email the lists, so just CTRL V the contents into the email.
Job done.
You could just as easily print it.
liam.mccaffrey
posted on 11/9/10 at 01:11 PM Reply With Quote
I do this a LOT
I have a little dos batch file I use to do this. you drop it in the folder and double click and it generates a text file in the folder.
I'll post its contents when im in work next
Build Blog
Build Photo Album
mad4x4
posted on 11/9/10 at 01:43 PM Reply With Quote
Originally posted by Rek
old school
dir > atextfile.txt
at the dos prompt do
dir /b >atextfile.txt
this will create a list of files but this will not have all the other crap like size, attributes etc.
Scot's do it better in Kilts.
