Longerr
posted on 6/1/11 at 08:35 PM |
AT Power vs SBD Motorsport
Hi guys,
I'm new here and just looking around and would like to get some advice from you. We just recently bought a Duratec HE 2.0 engine for a Lotus 7
replica and I'd like to buy throttle bodies for it to get some 200BHP. I'm deciding between
AT Power http://atpowershop.co.uk/catalog/ford-duratec-p-160.html
and SBD Motorsport http://www.sbdev.co.uk/Duratec/Duratec%20Basic%20Taper%20throttle%20kit.htm
The price difference is important for me but I don't which one is better and do provide both of the solution the complete kit without needing
any more parts to buy? I know that AT Power solution is not included with injectors but SBD is using too big injectors in my opinion.
I would appreciate any advices that would help to decide which one is better solution for the money
will121
posted on 6/1/11 at 09:06 PM |
think there may also be other options like jenvey TB's and emerald ECU and Omex, only issue with the other two might be worth checking which RR
are able to map the SBD any Typhone
westy turbo
posted on 6/1/11 at 09:40 PM |
Buy the whole ki from SBD,i did in 2002 in my old tigra.and then he came to Greece for tuning and that was the
only think it needed.was premaped,and was really good,so fine tune it in a RR and you good to go.as far as parts,
you can buy all you going to need from one shop, and that can provide support!!!
perksy
posted on 6/1/11 at 10:13 PM |
It will need final set-up and mapping to suit your particular engine
Decide where you will be taking it for Rolling road set-up and ask them which ECU they prefer and also which ECU/S they can map
Bare in mind that without a decent exhaust manifold and system you won't get anywhere near the claimed figures
I've Personally have had Good service from SBD so would recommend them
For Rolling road set-up I'd recommend Troy at Northampton motorsport
Longerr
posted on 7/1/11 at 10:08 AM |
Thanks for advices, I'm looking for some easy to put together solution, because I don't know much about fine tuning of the throttles, so I
think that BSD is the best option it's just a bit pricey, but probably I have no other choice. I will be making custom exhaust manifolds
according that one that was on the BSD webpage so all together I hope I will get around 200BHP
http://locost.webnode.cz/fotogaleria our build so far
mggareth
posted on 8/1/11 at 12:28 AM |
hi
i have used both setups and have found the AT setup to be very good. it is what i use on many engines.
the sbd setup is made by jennvey
gareth
Longerr
posted on 9/1/12 at 01:57 PM |
So SBD is based on jennvey? That I didn't know. I'm going probably to use AT Power, but I'd like to know your opinions on the
exhaust I should use. I'm looking for something like this http://www.raceline.co.uk/products/part_section.asp?SectionID=29&CategoryID=1 but
I'd like to know the diameters of the pipes that are used for 200bhp duratec engines
loggyboy
posted on 9/1/12 at 02:38 PM |
Maybe an weber alpha kit? Good rep company and circa £2k with everything you need.
Longerr
posted on 9/1/12 at 02:47 PM |
I'm not too much in to weber . What I wanted to know if the Sbd is worth the extra £500, thats a lot of money and the declared power of those
two kits is about the same
karlak
posted on 9/1/12 at 04:00 PM |
After a lot of research I went for Jenvey Direct to Head TB's
MK Indy - 2litre Duratec - Omex 600 - Jenvey throttle bodies - ETB DigiDash2
Longerr
posted on 9/1/12 at 05:19 PM |
Could you tell me why have you decided like this and what ECU do you use because I could find only Omex supplyed with Jenveys
karlak
posted on 9/1/12 at 05:35 PM |
U2U sent
posted on 9/1/12 at 08:10 PM |
As others have suggested where are you looking at to get everything set up after installing? I have an Emerald ECU in my car and found Dave Walker to
be very helpful , it was easy install,to get running and set up enough so I could put a few miles on the car before the rolling road session. Dave has
regular articles in PPC magazine in case you haven't seen them and also has written a book on engine management that I found very helpful.
Might be worth putting your location in your profile? No connection , just a satisfied customer.
BaileyPerformance
posted on 10/1/12 at 12:33 PM |
perksy - Noticed your in Shropshire, we have a RR in Broseley, Telford just for your info.
As for the throttle bodies, we use Jenvey with megasquirt
