Author: Subject: brake fluid caps
blakep82
posted on 20/1/11 at 04:33 PM Reply With Quote
brake fluid caps
what ones are folk using for wilwood master cylinders with integral resevoirs?
i've heard of ford ones, but i'm not sure on the height of them. ie, how far down the flot hangs. a bit worried the bottom of the resevoir with push the switch up, making it show its ok even when empty
________________________
gavin174
posted on 20/1/11 at 05:25 PM Reply With Quote
I was on the understanding internal reservoires will not pass IVA as there is no float switch...
Rally Design do a universal float switch that you may be able to fit.
fluidslvr
posted on 20/1/11 at 07:21 PM Reply With Quote
these work a treat...
http://www.cbsonline.co.uk/product/BRAKE_FLUID_RESERVOIR_CAP_FLCAP
http://mkmidi.blogspot.com
