bazz81
posted on 20/3/11 at 10:13 PM |
diff. bolt loose??
Hi There,
Yesterday i took my mk indy for the dirst day drive this year, but...
Everytime when i hit the gas, or just go off the gas, i heard a clicking sound.
At the gas station i looked at the mounting bolts of the diff thru the chassis, and the lower bolt was loose. (i can rotate the bolt)
but becouse the bolt is in a slotted hole, im not sure if that bolt must be very tight??
Can i tighten the nut/bolt, so that i cant rotate the bolt anymore?
matt_gsxr
posted on 20/3/11 at 10:59 PM |
Diff should be solid mounted to chassis. Tighten the bolt.
Hole is probably slotted because it was drilled incorrectly first time.
mistergrumpy
posted on 20/3/11 at 11:27 PM |
Somebody else posted this problem a while back after a lot of looking. I can't remember the solution but I do remember that the suggestion was
made of welding a washer or two one each slot so that you have a fixed hole to help eliminate that slop and click.
mad4x4
posted on 21/3/11 at 05:56 AM |
Ah that might explain the occasional cluck I get twith my INDY if I pull away hard......
Scot's do it better in Kilts.
snapper
posted on 21/3/11 at 07:40 AM |
And locktight the bolts.
I eat to survive
I drink to forget
bazz81
posted on 21/3/11 at 05:58 PM |
Thanks for al your input! I will tight the bolt/nut very soon, and give it some locktite.
