mantisgb
| posted on 13/4/11 at 04:31 PM |
Facet 40105 pressure
Sorry if this is a real beginners question - is there any adjustment possible on the pressure output from a Facet 40105 fuel pump? Is it based on
voltage? It is rated in various places from 2.5 - 3.5 psi and then other places at 3 - 4.5psi - but that being a range, how do you get a given
pressure?
I've replaced fuel pump, disi cap and rotor arm, and without racing round my local village I've got no way of telling if this weekend will
be a disappointment due to mechanicals or not (its more than likely to be down to my driving, but we'll see !
blakep82
| posted on 13/4/11 at 04:42 PM |
what pressure do you actually want? you'll most likely need a pressure regulator. theres loads of different ones out there.
filter king, sytec etc etc
________________________
| posted on 13/4/11 at 07:35 PM |
There are at least different versions of the little solid state pump ( http://www.fuelsystem.co.uk/web-facet.pdf ) Webers like the pressure 2.5
to 3.5 psi measured with the engine not running but if the float valve is in good nick will cope with 4 psi. On carb systems if you can avoid addon
pressure regulators do so (injection pressure regulators use a different priciple) select the correct pump to start with.
