M$RK_VXRD
posted on 21/4/11 at 10:20 PM |
garage clearout - plenum, carb, sarter wheel etc
Right i have decided to have a clearer out to raise some more funds for my engine swap i can take any of these to stoneliegh show on the monday or you
can collect would prefer not to post any heavy items!
if you would like any of the items if you email me mark.whinfrey@gmail.com i can garantee a fast reply!
Griffin zetec in let plenum (FWD easy to make RWD if you can weld) comes with injector rail and loom £120 ovno
Pinto Starter motor £10
Mountney steering wheel with sierra boss £20
Sierra steering wheel £5
DFTH 28/30 weber carb on pinto manifold £20
GTS floor mounted pedals £5 i can clean and powder coat you these for an extra £5
BRISCA throttle Braket £10
Air Filter £5
i may add some more things if owt else crops up!
[Edited on 21/4/11 by M$RK_VXRD]
austin man
posted on 21/4/11 at 10:48 PM |
what engine are you fitting
M$RK_VXRD
posted on 21/4/11 at 11:05 PM |
1.8 zetec blacktop just need cvh starter pinto one is in way of my mount, alternator and a clutch release bearing i think thats it o yeah and a load
of spare time lol
austin man
posted on 21/4/11 at 11:17 PM |
why arent you using the Griffin system I understood it gave a small power gain. I have the 18 silvertop on Bike carbs
M$RK_VXRD
posted on 21/4/11 at 11:28 PM |
Because I want to run the original ecu so I would have to modify it to take the idle control vavle and it seams a shame to mess about with it if
someone else can make better use of it and I will just make my own
gavin174
posted on 22/4/11 at 06:32 AM |
yes please to inlet plenum and Brisca throttle bracket
u2u sent
Rob E
posted on 22/4/11 at 07:35 AM |
What size pipe would fit the filter??
No it's not new I've had it for ages!!!
M$RK_VXRD
posted on 22/4/11 at 09:00 AM |
3 1/2" - 90 mm I must point out it is not a piperx filter sorry for the miss leading pick I didn't know big wasa has just pointed it out
to me as it was originally his.
M$RK_VXRD
posted on 22/4/11 at 09:01 AM |
Plenum and throttle bracket now SOLD
u2u sent
M$RK_VXRD
posted on 24/4/11 at 09:43 AM |
Mountney steering wheel and boss provisionally sold
M$RK_VXRD
posted on 25/4/11 at 11:03 PM |
couple of extra things to add -
7" black headlights (ones on the gts pics in my photos) £15
aftermarket ignition switch with 2 keys £5
Pair of rubber pinto engine mounts free to good home
also the mountney wheel and boss may still be forsale as the buyer seams to have gone quiet
[Edited on 25/4/11 by M$RK_VXRD]
M$RK_VXRD
posted on 26/4/11 at 02:54 PM |
Pedals are now sold
HomersDouble
posted on 26/4/11 at 03:17 PM |
I'm interested in the headlights - I'll send u2u
owelly
posted on 26/4/11 at 03:43 PM |
2nd dibs on the headlights? U2U on it's way....
http://www.ppcmag.co.uk
M$RK_VXRD
posted on 26/4/11 at 04:34 PM |
Ignition switch, headlights & pedals now sold
