Cornishman
posted on 26/7/11 at 09:23 AM |
Rollbar for hillclimb use?
Hi, I have been searching through some of the rollbar/rollcage topics for a few days now and can see that it can be a slightly contentious issue!!
I am intending to return to speed hillclimbing after a break of 10 years or more and am looking at using a Locost or similar type vehicle.
I am currently looking at a couple of former 750 motor club cars that fit the bill, and could most likely be adapted and developed for hillclimb
use.
My question regards the roll bar or cage. 750 club regs demand the use of a 6 point cage as per blue book etc etc. The MSA hillclimb (S) and safety
(K) regs appear to indicate that a basic rollbar is sufficient for vehicles under 2000cc and this is borne out by my experience spectating at some
local hills this year.
The rollcage on the cars I am looking at does not appear to meet the new circuit racing/750mc rules and is certainly not approved or certificated so I
will have to remove it. I wish to fit a basic rollbar as per the drawings in the blue book. but all the info that gets discussed concerns the more
elaborate and heavier 6 point full cages for circuit racing use.
I would be interested to hear from anyone with speed event experience regarding fabrication or purchase of suitable roll bar that meets speed event
regs.
Thanks in anticipation of any help.
phelpsa
posted on 26/7/11 at 09:39 AM |
I have one in my garage that is to MSA regulations and will fit a book chassis. I went full cage so no longer needed. It was bought from Stuart Taylor
about 6 years ago and never used.
As in this picture:
I think it cost me about £150, yours for £100.
procomp
posted on 26/7/11 at 10:28 AM |
Hi
The 750 regs you refere to are specificaly for a championship with a full cage. You need to follow the blue book general regs. IE 45mm rollbar with
diag and rear stays. Or buy the one above.
Cheers Matt
minitici
posted on 26/7/11 at 10:53 AM |
Steve, What category will you be running the car in?
For a fully road registered and road legal condition car you do not require a roll bar or cage (but is highly recommended)...
For non-road categories there are MSA minimum requirements for ROPS and these can vary depending on the exact category entered - you need to have a
look at the MSA blue book to find which are applicable.
There is no such thing as an "MSA approved" roll bar or cage - only bars and cages which meet the criterial set out in the blue book.
Cornishman
posted on 26/7/11 at 02:07 PM |
Excellent, thanks for the responses so far.
I am going to be running (hopefully) in the modified class because the cars I'm looking at are not SVA'd and therefore not road legal.
I have studied the diagrams and text in the blue book and I think I have a reasonable understanding but would still appreciate any comments or advice
anyone has.
The South West championship that I will intend to run in doesnt specifically request a full ROPS system, it just makes reference to the MSA blue book.
The blue book seems to suggest that I can run a roll bar as pictured rather than a full ROPS.
Once I have got a car to work on and alter for hillclimb use then my next sensible step would be to contact the championship scrutineer for guidance,
although based on my specating this year it seems like I am correct in my assumption.
The cage pictured is the sort of thing I had in mind, as long as the tubing is the right diameter then I am very interested, thanks.
My location might be a problem as South East Cornwall is along way from anywhere and roll bars arn't easy to post!!!
If we can come up with a way around this then that would be great!!
Regards
Mike Wood
posted on 6/2/12 at 10:46 PM |
Hi
Is this roll bar still for sale?
Mike
As in this picture:
