tompat3463
posted on 1/8/11 at 01:39 PM |
Turbo'ing a blade 919 ?? how easy / challenging ??
as the title really.. im thinking seriously about turboing if possible my 919blade indy..
just wondering how hard or easy it would be ??
what exactly would be the shopping list ??
could this be done using the standard 919 carbs and a plenum ??
where would I pick an oil feed from on the bike engine ??
TIA Alan
mark chandler
posted on 1/8/11 at 03:12 PM |
Have a look here
The lockup clutch is a defo here I paid for the intial drawings so
paid £400 for mine, you will need a clutch spacer from Andy7wide, I junked carbs and used 954 TB's on a homebrew inlet as the spacing does not
match.
Oil comes form the big bung that the oil pressure sender fits in.
You also want to budget for an accusump and 3.14 LSD
Is it worth it? YES
[Edited on 1/8/11 by mark chandler]
ReMan
posted on 1/8/11 at 03:25 PM |
This is my winter project.
Simple and locost as possible, on carbs.
Start with the "right" turbo and work round it.
I'm looking into the "right turbo now"
theres a few threads on here on this topic
www.plusnine.co.uk
mark chandler
posted on 1/8/11 at 03:39 PM |
You do not need any more than 8psi max, I run 7psi which saves having to purchase a head gasket and spacer so saving ~£200.
These are found on 2.0-2.3 volvo's, it what I was going to use until Scootz came to the rescue
http://www.locostbuilders.co.uk/photos.php?action=showphoto&photo=Turbo_part_No.JPG
Regards Mark
Spaz
posted on 1/8/11 at 05:10 PM |
Another good site for info is http://www.bike-turbo.com/forum/
tompat3463
posted on 1/8/11 at 06:21 PM |
I take it the stanard trumpets would be disregarded and a bolt on plenum would be required ??
cheers Alan
posted on 1/8/11 at 06:26 PM |
I think Joe (welderman) is/has turbo-ing/ed a blade engine.
Maybe worth dropping him a U2U.
It's Evolution Baby!
johny p
posted on 1/8/11 at 07:31 PM |
yeah.. welderman is the man to speak too hes done one.. hes on his hols tho i think at tho moment... the bastard!!.
posted on 1/8/11 at 07:51 PM |
A blow through turbo setup with carbs (particularly multiple carbs) is not particularly simple. Carbs are naturally velocity sensitive devices, you
need to make them pressure sensitive as well unless you are keen on melted pistons.
This was discussed a while back.
matt_gsxr
posted on 1/8/11 at 08:35 PM |
I think your definition of "need" and mine are different
mark.s
posted on 1/8/11 at 08:46 PM |
this might help
http://www.holeshot-racing.co.uk/uploads/File/tbikehonFireblade91_98.pdf
good luck
hiflow
posted on 1/8/11 at 08:55 PM |
Looked at doing one about a year ago and spent a LOT of time researching. Told i would need to rebuild the bottom end every 2k. Was going to blow
through TB's , therefore i would aftermarket ecu. Added up the price of TB/ECU/Pistons/ Forged valves/ oil cooler/ intercooler/ custom plenium /
water injection / turbo /manifold / RR setup and i was very quickly into ZZR / Busa money. Ok for a sunday drag bike, but felt i would never have
my hand out of your pocket. Must admit, 180bhp out of light weight blade DID appealed to me, but the new CBR rr / Zx10-r / R1 and GSXR 1000 are
+180bhp with ram air. The T blade would give more torque. In short , i did not have 'balls' todo it, so i went for zzr14. Cannot beat
CC's
mark chandler
posted on 1/8/11 at 09:19 PM |
Mine runs 7 PSI, completely standard engine and has yet to blow up @200bhp ! when its £400 an engine when it does go bang I will just swap out.
It made no nasty noises on the RR, pulling a plug and all looks nice and clean, no ali stuck on the plugs etc.
I,m sure all those expensive bits will help but the gearbox and clutch will be struggling if you wound up the boost, as it is now I have busa power
without the cost or weight.... and I can afford for it to go wrong as no dry sump etc to worry about if the engine blows.
2000 miles is a lot of track time, I just change the oil each outing to play safe.
I should add, I spent considerably less than holeshot are quoting to do mine
hiflow
posted on 1/8/11 at 09:26 PM |
well done.
gaz_gaz
posted on 1/8/11 at 09:44 PM |
do you happen to know the torque figure at 7psi Mark?
mark chandler
posted on 1/8/11 at 10:03 PM |
It will hit the rev limiter in top about halfway up the pit lane at Brands, with the little slicks and 3.14 diff that's about 135mph
The bit that needs tuning is the driver.....
tompat3463
posted on 1/8/11 at 10:20 PM |
Mark what turbo did u use ??
Steve Hignett
posted on 1/8/11 at 10:23 PM |
I thought I'd add a "Well done" too.
However, I'm afraid mine is just a genuine well done, I mean it without any petty sarcasm...
mark chandler
posted on 2/8/11 at 08:37 PM |
One of these
Mine was second hand from Scootz, a very lucky purchase
