mark w
posted on 4/8/11 at 12:54 PM |
daytime running lights
hi all, just wondering if i have got to have daytime running lights for iva or if i can get away with not fitting them? if so, is there any good kits
i should look out for?anyone fitted any? pics?
Cheers mark
[Edited on 4/8/11 by mark w]
Davegtst
posted on 4/8/11 at 01:00 PM |
As far as i know they are optional at the moment. Personally i would fit them after the test then you don't have to worry about them being the
cause of an iva failure.
russbost
posted on 4/8/11 at 01:25 PM |
Not required for the test & as said above best fitted afterwards. When you're ready I have some very nice little units for under a tenner!
Daddylonglegs
posted on 4/8/11 at 02:20 PM |
Any more info on them Russbot?
RK
posted on 4/8/11 at 03:04 PM |
They are mandatory in Canada and have been for a long time. You can use anything you want though; and i've used very cheap LED's that fit
beside the headlights. They look great, and in the next century when my car is finished, they will look even better on the roads.
AndyW
posted on 4/8/11 at 05:20 PM |
just use side lights. Locost.
russbost
posted on 4/8/11 at 05:43 PM |
Here you go!!
Link where I offered a discount!
Link to my webshop for more info!
iain b
posted on 4/8/11 at 07:37 PM |
russ.......that is very clever.and very simple.and very cheap.and very easy to fit....
keith777
posted on 4/8/11 at 08:02 PM |
I was so impressed I've just bought some !!
cheers Keith
russbost
posted on 4/8/11 at 09:53 PM |
That'll be the wind powered ones then! I'm sure you'll be pleased with them!
Have to say I was a bit skeptical until I saw the samples, to test them you can just blow hard at the fan & they light up! There's a set
definitely going on my next Furore! See if I can remove the "cloak of invisibility!"
mark w
posted on 5/8/11 at 08:40 AM |
That's exactly what I wanted to hear thanks, that way I can have a good think on what i want & where to fit them afterwards
