Nick DV
posted on 24/8/11 at 07:48 PM |
Battery Master Switch - Where to put it?
Is there any reason/preference where to put the above? Does the switch have to go into the dash or can it go on the outside of the scuttle like the
Caterhams? I can put mine on the dash on the passenger side and reach it easily, however it would be easier to go on the scuttle as it means that dash
removal is easier and less re-routing of wiring?
Can anyone let me know if it's ok to put in either position or if one is better than the other.
Cheers, Nick
"The force will be with you, always!"
Ben_Copeland
posted on 24/8/11 at 08:18 PM |
Pre or Post IVA
Forget about reaching it or having it on the dash for iva test, put it in engine bay.
Post iva, put it wherever you like
[Edited on 24/8/11 by Ben_Copeland]
Ben
Locost Map on Google Maps
Roadster
Enter Your Details Here
Nick DV
posted on 24/8/11 at 08:26 PM |
quote: Originally posted by Ben_Copeland
Pre or Post IVA
Ben, won't be IVA'd as the car is for track use only.
Cheers, Nick
Ben_Copeland
posted on 24/8/11 at 08:27 PM |
Pre or Post IVA
Cheers, Nick
See my edit above
Ben
Roadster
Nick DV
posted on 24/8/11 at 08:32 PM |
I see Ben. Deffo not in the engine bay Probably will put it on the side of the scuttle unless advised otherwise.
Cheers, Nick
Ben_Copeland
posted on 24/8/11 at 08:45 PM |
Good enough for caterham, but it might need a little protection. Save it from being snapped off by someone or something
Ben
Roadster
AntonUK
mine is in the centre console with a remote cable to the scuttle... best of both worlds
Nick DV
posted on 25/8/11 at 10:22 AM |
Good idea but don't want to run the cabling there or have a pull cable there.
Cheers, Nick
posted on 25/8/11 at 10:24 AM |
Offside of scuttle seems to be the place most racers choose on their se7ens.
It's Evolution Baby!
procomp
posted on 25/8/11 at 11:51 AM |
Hi
First off assuming it is being used under MSA conditions it is the type with the 4 spades and resistor. ?
These switches are a PITA reliability wise so needs to be accessible quickly when problems do occur. They also do not like being exposed to damp /
moisture. Also you SHOULD be able to operate it whilst fully strapped in to the car to shut it off but also have it in a position where marshals can
easily reach it should you not be in a fit condition to do so.
Personally i think where Caterham mount it is absolutely ridiculous. As it leaves it open to moisture ingress both whilst being used on track and
whilst in transport and also leaves it open to the elements during an accident which has been known to render it inoperable when damaged. Again
personally placing it out of harms way somewhere that's accessible from both inside and outside whilst also keeping it away from the weather
element is the best place which usually ends up being on / through the dash or on top of the tunnel area with a bracket under dash with a suitable
located exterior pull cable for marshal operation.
Cheers Matt
Nick DV
posted on 25/8/11 at 01:38 PM |
Matt, it is the FIA type. I will go for a dash mounted position then - I can reach it and it can be easily reached from outside.
Cheers, Nick
Neville Jones
posted on 9/9/11 at 09:56 AM |
Hi Nick.
Latest MSA wording would have a remote placed on the drivers side, where the A pillar would be.
Q 19.11.1
K 8 (all of section) K 8.3
MSA Blue Book is on line. Search MSA Blue Book 2011 online.
I'm getting to know this publication quite intimately these days.
Don't forget your yellow tape on the battery negatives/earths, and your (min 60mm internal diam) tow loops, painted red/yellow/or orange.
You've got an MSA scrutineer not far away from you, if you want clarification.
Nev.
Nick DV
posted on 9/9/11 at 11:38 AM |
Hi Nev,
Thanks for that. I will have a look at the on line blue book. Have done the yellow tape already, but will need some tow loops.
Cheers, Nick
andylancaster3000
posted on 9/9/11 at 12:09 PM |
Agree dash is a good place for it. We put it on the right side of the steering wheel. Keeps the key in reach, out of harms way, keeps the scruits
happy and is in the exempt SVA (and IVA?) zone.
