owelly
posted on 13/1/12 at 10:09 PM |
wtd. Sierra drive shaft bolts and hub nuts.
As the title. Both hub nuts have been butchered with a cold chisel and even though most of the drive shaft bolts came out without fighting too much,
I'd like to fit new ones. There's a couple of bolt sets and hub nuts on Ebay but I thought I ask here first.
TIA.
http://www.ppcmag.co.uk
daniel mason
posted on 13/1/12 at 10:45 PM |
if they are the bolt on shaft bolts you want i have a load spare.brand new as i needed some for my shafts. ill chuck em in with the silencer if you
want them. let me know asap so i can post it to you
owelly
posted on 13/1/12 at 10:52 PM |
That would be most excellent. Cheers.
daniel mason
posted on 14/1/12 at 04:59 PM |
ok mate. think ive got 12 of them if thats ok
DRCorsa
posted on 14/1/12 at 05:36 PM |
I replaced the stock Torx bolts with the exact same ones, except the head was Allen.
Torx may be a pig to remove, i know because i have broken a pair of Torx bits along the way..
[Edited on 14/1/12 by DRCorsa]
