Supergoose
| posted on 29/4/12 at 10:09 PM |
xflow optimum squish
Could some one please tell me the optimum squish for a locost xflow, I'm used to working with bikes with much lighter rods/pistons but they rev
much higher but I don’t know what you need to account for,for elasticity?
Please help as i want get the gasket and get racing!!!
snapper
| posted on 30/4/12 at 07:22 AM |
Crossflow has chamber in piston and a flat head so squish is not relevant as pistons will be down the bore.
In a pinto squish is a minimum .75mm with .9 recomended for 8000 rpm
Basically you are building in a margin for rod growth and piston rock
[Edited on 30/4/12 by snapper]
I eat to survive
I drink to forget
mcerd1
| posted on 30/4/12 at 01:33 PM |
a few more details about your engine spec / size might help...
is this a 750mc car ?
yeah, I've got my pinto's pistons flush with the top of the block and a 1.0mm gasket - hope it works
[Edited on 30/4/2012 by mcerd1]
Supergoose
| posted on 30/4/12 at 07:35 PM |
Sorry yes it's a locost and I don't agree with the comment that squish isn't relevant with a flat head, focusing the burn to the
combustion chamber is key regardless of weather it's in the head or the piston
Richard Jenkins
| posted on 30/4/12 at 08:03 PM |
This from the 750MC Locost regs - "Gasket: The cylinder head gasket must have a minimum compressed
thickness of 0.85mm and a minimum cylinder aperture of 82.5mm"
mcerd1
| posted on 30/4/12 at 09:02 PM |
I think snapper is just talking about piston / head contact, where as your thinking about compression ratio....
but like richard says there isn't alot of options if you've got too meet the 750MC Locost regs
Supergoose
| posted on 30/4/12 at 10:09 PM |
not at all, surely the closer the non combustion areas of the piston are to the head the more accurate the burn is focused to in the comustion chamber
and not seeping across the whole face of the piston. but maybe im understanding it properly?
Supergoose
| posted on 30/4/12 at 10:10 PM |
true about the regs mind you
snapper
| posted on 1/5/12 at 05:37 AM |
My comment about not being relevant should of perhaps said "not achievable" if you look closer at my post i also gave pinto squish
distance.
You can't get that close with a flat head unless you have very deep piston bowls therefore the edge of the pistons will not be close enough to
the head to create any squish, if the piston bowl edge was close enough there would be very little squish as not much of the piston is close
enough.
The swish on a pinto is where the chamber, which has large flat areas and flat top piston get really close as said 0.75 to 0.9mm is the target.
How far down the bore are your pistons?
Standard 1600 pistons are further down than the 1300 pistons would be that are used to increase compression.
I eat to survive
I drink to forget
Supergoose
| posted on 1/5/12 at 06:13 PM |
Nearly flush
procomp
| posted on 1/5/12 at 06:40 PM |
Hi
As mentioned there is the min compressed thickness for the gasket IE using a Payen or similar standard type gasket. Copper or similar reduced
thickness ones are non compliance with the dimensions stated in the regulations. Piston not to protrude above block face. Piston dimensions as in
bowl depth / dia and radius in the bottom off the bowl + valve cutout dimensions are all checked by the scrutineers and comparisons are made to
standard parts with the correct dimensions.
Also the valves have to remain as STD. The scrutineers have pattern parts, as some have already tried to take the mick with that area of the
regulations already.
Matt ( Locost drivers rep )
