Author: Subject: Are these legal under 750MC rules
Disgruntled karter
posted on 1/5/12 at 01:17 PM Reply With Quote
Hi
Can anyone confirm if these dashboards are legal under Locost 750 MC rules
http://www.etbinstruments.com/DD2_lite.htm
procomp
posted on 1/5/12 at 03:29 PM Reply With Quote
Hi
YES there are a few locosters using them. However the rev counters and temperature readings are not very accurate. Water temp can be out by as much as 15 deg with the sender units they use. !!!
Personally i go for a highly accurate water temp and oil pressure gauge and a decent rev counter. If you really want a data logger then it is worth investing in one that is easier to expand and adapt if looking long term.
Cheers Matt
Disgruntled karter
posted on 3/5/12 at 05:04 PM Reply With Quote
Hi matt
Any suggestion for what you would recommend either the separate rev counter/temp/pressure gauge route or 'digi dash' type solution
