Author: Subject: strange revs problem
markyb
posted on 28/5/12 at 06:42 PM Reply With Quote
I was out on a run at the weekend but was getting erratic revs when the car was idling/sitting in traffic - sometimes it was near normal eg below 2000 rpm but other times it was as high as 6000. Once I started pushing the clutch pedal when the revs were high they would again drop back to normal idling levels
has anyone come across this before or have any idea how I could fix this
thanks in advance
tomgregory2000
posted on 28/5/12 at 06:55 PM Reply With Quote
Go on give us a little clue as to what engine you have, fuel system, ignition.....
markyb
posted on 28/5/12 at 07:48 PM Reply With Quote
thought I would try and draw out the suspense.............
03 R1 with foot clutch cable and barnett clutch plate installed with
fueling is managed via power commander
coyoteboy
posted on 28/5/12 at 08:41 PM Reply With Quote
My first thoughts are straight to the throttle bodies/cables, then the idle control valve on the throttle bodies. One thing that might get you - check the TBs are actually clamped in properly.
markyb
posted on 29/5/12 at 08:29 PM Reply With Quote
thanks for the help - will check out the throttle bodies first as they were removed a while back
might also tighten the throttle return spring as a precaution
