mtechmatt
posted on 13/7/12 at 02:12 PM |
Mapping of Ben Copelands XE powered Haynes Roadster
Chaps,
Ben has just set off, and I said I would email his graph but I thought may as well post it up!
(The red curve is at 50% throttle as a part throttle test of torque)
Spec wise, I'll let ben explain but from what I saw, a 2.0 XE running GSXR TBs and on of our V3 Megasquirt units.
Good session, had a couple of issues, with a very disturbing noise coming from the rear wheels, which turned out to be the wheel weights hitting the
calipers ever so slightly, but after spotting it this we were relived and got stuck into the mapping.
Well put together engine, though there was some cooling bugs somewhere and I suggested Ben ask you guys as to which way to go with heat management on
an XE... seemed to run away to over a 100*c with only light load. This prevented me from being able to hold the car at steady states for tuning, but
after balancing the bodies (we had it idling as low as 400rpm after that!) I was able to get the shown results by repeated power running and tuning in
between...
Ben took it for a test run after and came back with a grin so we were happy at our end, but I will leave him to post final feedback
Moving forward, if he can put a decent manfiold on there (there were intake lips of around 5mm where the bodies joined the standard intake) that would
free up a few more ponies!
Good stuff
[Edited on 13/7/12 by mtechmatt]
V4 Engine Management System | Online Shop |
Rolling Road Tuning | Motorsport
Preparation | Engine Packages | Throttle
Bodies
Check out what's happening in the workshop via our Facebook Page:
The Workshop
MEGASQUIRT ROLLING ROAD & BIKE CARB TUNING SPECIALISTS
www.mtechautomotive.co.uk
deezee
posted on 13/7/12 at 03:30 PM |
Am I being thick? But didn't the C20 XE produce 150bhp as factory standard? I would have expected a freeflow exhaust and individual throttle
bodies to free up some more power?
mtechmatt
posted on 13/7/12 at 03:41 PM |
Deezee,
Yes we were hoping for more, but the port matching etc was quite a way out, and without being able to steady state tune it (due to overheating) the
aim of the game was to make the car driveable and smooth, which is what we achieved.
Matt
Bodies
The Workshop
Ben_Copeland
posted on 13/7/12 at 04:14 PM |
Theres a few things that need doing to get the power up, but i'm happy with it for the moment. It starts and idles nicely and cruizes smoothly.
Plus flys when you push the throttle!
Ben
Locost Map on Google Maps
Roadster
Enter Your Details Here
omega 24 v6
posted on 13/7/12 at 05:39 PM |
Ben did you upload the map I sent you?? If so how far out was it?? I'm interested to see where Mines may be wrong especially the ign timing map.
mtechmatt
posted on 13/7/12 at 05:48 PM |
Omega,
No I remapped it.
The feuling map was all over the place lots of bumps and hills (though ben may of used the autotune stuff), spikes etc, that needs looking at,
ignition was ok, bit retarded at top end at only 36*, I got away with 39 on Bens at WOT.
The actual powr wasnt too far off, however far too rich up to around 3k, but after that running around 12.1:1 so leaned that off slightly but I assume
for a self road mapped job it was pretty good
If you're running the same setup I suggest getting Ben to send you a copy
Matt
Bodies
The Workshop
perksy
posted on 13/7/12 at 06:33 PM |
Ben
Is your XE piped up as per the cooling system diagram on the SBD website ?
omega 24 v6
posted on 13/7/12 at 07:11 PM |
Ben asked me to send him my map but i'm not sure if he uploaded it prior to you getting your hands on it.
It was a self tuned using tunerstudio and a bit of guestimating TBH.
Mines is a v2.2 ms1 with wasted spark and gsxr 1000 bodies Matt.
I also found that leaning it out to over 13.5 causes huge problems with misfires etc and VERY poor idling. It seems to be a much happier engine at the
12.5 to 13 max AFR
Ben_Copeland
posted on 13/7/12 at 07:19 PM |
quote: Originally posted by perksy
Ben
Not exactly but i'll post a separate thread for that.
I cant remember what i did with your map omega. Think i took the tables over to mine and tried it.
Ben
Roadster
mtechmatt
posted on 14/7/12 at 10:23 AM |
12.5 to 13 max AFR
Most engines should idle ok at around 14.5-15.0. For WOT I usually run between 12.5.13.8 de[ending on the engine, never above 14 though!
Bodies
The Workshop
