Author: Subject: carlton gearbox oil recomendations with C20XE
nickw2000
posted on 16/7/12 at 08:47 PM Reply With Quote
trying to find out with no luck, what gear oil the carlton gear box should be? if anyone knows please that would be great so i can drain and refill the gearbox.
also what rating gl4 or 5 ?? semi or full ??
posted on 16/7/12 at 09:18 PM Reply With Quote
GL4 SAE 75W-90
ie Comma SXGL41L 1L SX75W-90 GL-4 or Castrol Syntrans Multivehicle 75W-90 G-L4
nickw2000
posted on 16/7/12 at 09:26 PM Reply With Quote
would anyone recomend the extra cost of redline mt90 75/90 fully synthetic gl4?
posted on 16/7/12 at 09:56 PM Reply With Quote
Any decent GL-4 oil of the correct viscosity range will do the job, even a good quality 10w/40 engine or Dexron type transmission fluid will do job.
Gears in gearboxes don't tend to to fail from metal to metal rubbing contact.
nickw2000
posted on 17/7/12 at 10:42 AM Reply With Quote
Opies recomend 70/80 gl4
