Xtreme Kermit
posted on 31/7/12 at 06:51 PM |
VTEC Jus How Does It Work?
I thought I knew how variable valve timing worked, by applying oil pressure to the cam/sprocket to vary the relationship between them.
But looking at a Honda VTEC head, they don't work like that.
Anyone know how they work? And are they the only two methods?
Daddylonglegs
posted on 31/7/12 at 07:00 PM |
Spooky! Just been talking to my eldest about V-Tech, he's got a Civic Type-R.
Try this link
JB
Xtreme Kermit
posted on 31/7/12 at 07:13 PM |
No wonder the head construction looks a little odd, you have the cams and an idler shaft for each set of rockers.
I wonder if the Toyota one is the same [dives into google]
Xtreme Kermit
posted on 31/7/12 at 07:21 PM |
So it looks like the Toyota one uses the rotation of the cam against the sprocket and not the extra cam lobe.
http://www.youtube.com/watch?v=6AXh8O7hWU4&feature=youtube_gdata_player
posted on 31/7/12 at 08:43 PM |
The one that (IMO) is the cleverest by far is the MG-Rover VVC mechanism. It's the only system I know of that gives step-less control of cam
duration (from 220 to 295 degrees). It does this by continuously varying the speed of the cam as it turns - by slowing the cam down as the valves
approach full lift you effectively increase the duration.
Xtreme Kermit
posted on 31/7/12 at 08:56 PM |
Well there are many ways to skin the cat...
I guess the extra shafts in the vtec head contribute to it being a tall engine.
Interesting
loggyboy
posted on 31/7/12 at 09:30 PM |
IIRC its a little gnome that makes more noise but no acctuall power gains...
lol
Mistral Motorsport
Xtreme Kermit
posted on 31/7/12 at 09:34 PM |
I knew there would be magic in there somewhere
COREdevelopments
posted on 31/7/12 at 09:48 PM |
Toyota has a regular vvti and their sporty version is a vvtl-i (variable valve timing and lift). It uses the regular oil pressure sprocket along with
a complex cam arrangement to give the lift after 6000rpm.
Rob
StrikerChris
posted on 1/8/12 at 12:15 AM |
I've had the vvt sprocket apart on my nissan engine.The nissan sprocket is in 3 parts,the bit that locates on the cam,the outer which drives the
chain,and a helically splined shuttle in the centre.When the solenoid opens the oil pressure moves the shuttle down the pulley and thus slightly
advancing or retarding the timing because of the helical splines.
No idea how honda do it,their vvt sprockets are half the size (and weight!)
Chris
Xtreme Kermit
posted on 1/8/12 at 06:12 AM |
That seems to be because the Honda sprockets are passive, the vtec bit happens in the rockers brining the extra cam lobes into play. It looks like
vtec cams have an additional four lobes per cam.
posted on 1/8/12 at 07:53 AM |
The i-VTEC system (e.g. used in the K20A) uses a variator in the cam pulley AND dual cam profiles. I was investigating the aftermarket ECU
modification (K-Pro) that allows you to alter the fueling and ignition, and by god does the ECU have a lot of calibration! The Variator allows 50
degrees of cam timing change and the ECU has a fueling table for every 10 degrees. Then you have the dual cam profiles (high speed and low speed) so
that's ten sets of tables for fuel, and then another ten tables for ignition timing!
The VTEC system uses 3 lobes for two valves - at low speed each valve is operated by a separate lobe, the same as most conventional 16v engines. When
VTEC is actuated, the middle lobe which is larger with more lift and duration operates both valves together.
[Edited on 1/8/12 by MikeRJ]
posted on 1/8/12 at 07:55 AM |
lol
It makes some very impressive power gains, and more to the point the engine makes just as much power at low RPM as the majority of normally aspirated
production engines.
