tank81
| posted on 23/7/13 at 07:54 AM |
BULK SALE kit car stuff - MUST GO!
Morning All,
I have put the remnants of my garage stuff onto ebay with full descriptions and photo's as a BULK BUY as want rid ASAP!
Remaining buts are:
Set MK 2004 Wishbones minus Upper Rear Wishbones (New and Painted)
Set MK Nylon Bushes and Metal Inserts (Possible Full Set- Used)
Xflow Distributor (Used)
Xflow Distributor Cap and Rotor (New)
Xflow 86deg and 92degree thermostats (New)
Xflow Air Filter (New)
Xflow Coil (New)
Xflow High Pressure Oil Pump and Filter (New)
Xflow Radiator and Fan
Cortina/Escort Clutch, Handbrake and Throttle Cables (Mixed - Old and New)
Cortina/Escort Uprights and M16 Calipers and Discs (Used - Note: Not FIA Historic Spec)
Cortina/Escort 10mm Wheel Spacers (New)
Wilwood 0.625" Master Cylinders and Remote Reservoirs x 2 (New)
Wilwood 0.75" Master Cylinder w/integrated Reservoir (New)
80mm 120mph AST speedo and Sensor (Used)
80mm ETB 150mph Speedo (Used)
80mm ETB Rev Counter 14,000rpm (Used)
55mm Sunpro Oil Pressure Gauge and Capillary Tube (Used)
55mm Water Temperature Gauge and Sender (Used)
Frontera Aluminium Radiator and Fan (Used)
9" x 1.95" ID x 275lbs Springs Pair (Used)
7" x 1.95" ID x 300lbs Springs Pair (Used)
140psi (10bar) Fuel Pressure Regulator Kit (New)
Ebay Listing is under "Kit Car, Classic Ford, Formula Ford, Locost, MK, Race Car Parts" (sorry, can't get shortcut to save!)
I am open to offers around £300 for everything collected.
If it does not sell I may split
U2U me or call on 07920 007566
jossey
| posted on 23/7/13 at 08:02 AM |
ebay linky
David Johnson
daniel mason
| posted on 23/7/13 at 08:07 AM |
pm sent
adithorp
| posted on 23/7/13 at 08:35 AM |
Might get more response if you list it in the for sale section.
http://jpsc.org.uk/forum/
tank81
| posted on 24/7/13 at 08:22 AM |
Have moved my "listing", cheers
Thanks for the ebay link too.
