Author: Subject: Battery Cable
mkeats02
posted on 26/9/13 at 07:11 PM Reply With Quote
Battery Cable
I have a 40Amp Output Alternator, probably a silly question, but am I okay to run a 50A or 70A cable rather than a 110A or 170A rated battery cable?
Mike
This Monkey's gone to Heaven
Thruth does not exist, it is only Human Opinion
big-vee-twin
posted on 26/9/13 at 07:24 PM Reply With Quote
yes, you will need to put a 40 amp fuse in too, to protect your loom.
http://www.triangleltd.com
gremlin1234
posted on 26/9/13 at 08:14 PM Reply With Quote
a 40A alternator with 50+ A cable to the battery is fine,
and, no, you don't need to add extra fuses.
though do ensure the cable is flexible.
posted on 26/9/13 at 08:36 PM Reply With Quote
You can alternatively run the cable to the battery side main ring terminal of the starter solenoid, *don't use too heavy a cable as it won't be flexible enough, if you have an old style 3 blade block connector you should run a wire from each as the blades are only rated at 35 amps.
If you want to use a fuse you can use a 150 amp Mega fuse or Midi fuse on the main starter lead mounted in a holder close to the battery.
mkeats02
posted on 29/9/13 at 06:32 PM Reply With Quote
gremlin1234
posted on 29/9/13 at 07:33 PM Reply With Quote
you will still need the higher rated cable from battery to starter.
posted on 29/9/13 at 09:16 PM Reply With Quote
Yes, you need to use a heavy gauge wire from battery to starter but the wire from alternator to battery can be lower rated.
