unijacko67
| posted on 17/2/14 at 11:49 PM |
wanted, Night heater
Like the title says, has anyone got a cheap 12v diesel night heater with pump and all the bits for sale.
Cheers.
http://www.kittenkitcar.co.uk
carlknight1982
| posted on 18/2/14 at 03:33 PM |
I was looking for one for ages when i have my camper van,
i found it cheaper to buy a 24v one and run a 24v power supply off my inverter.
bit arse about face but about £300 cheaper
Logic will get you from a A to B
Imagination will take you everywhere.
unijacko67
| posted on 18/2/14 at 07:20 PM |
Might have a re think on that one, I wanted something for about £50.
CompoSimmonite
| posted on 19/2/14 at 07:10 PM |
You will be very lucky to get even a knackered 24v with parts missing for that amount. I had a surplus 12v unit and was shocked at how much it made on
eBay as the demand is so high so you should budget £250-300 for a working unit.
Also look for Propex heaters - they are a propane rather than diesel powered night heater and can be cheaper.
Paul H
jossey
| posted on 19/2/14 at 07:16 PM |
Calorfier is my purchase this week. Wired to a small convector rad and hot water cylinder. Runs off engine water heat and 12v and 240v
Give me hot water and hot rad.
I went to see one today and the rad stays warm for 3-4 hours off the engine heat from driving. Also on 12v tops up to last the night.
My plan is to have a rad with shut off valves to turn it on and off like a normal rad which won't effect the water heater part.
Costs £250 rather than lots mire for a new gas heater. Not keen on second hand gas items. Don't fancy death .....
David Johnson
