New Topic New Reply
Author: Subject: Which engine westfield build, c20let or z20let that is the question??
Masterman 809
posted on 5/4/14 at 02:23 PM Reply With Quote
BDMStriker
posted on 11/4/14 at 01:16 PM Reply With Quote
Does it have to be turbo'd? a well set up c20xe will be roughly 200-230bhp. i was advised against turbocharging as the non linear power delivery can affect driveablility
supercharged zetec? or supercharged c20let/z20let?
beaver34
posted on 11/4/14 at 02:00 PM Reply With Quote
or i would look at upping the turbo size and the engine revs to give top end and linear delivery like my turbo setup does
speccing the engine right for a lightweight car means that you do get usable grunt, you downt want peak torque at tow revs and a big boost spike
i run 340bhp on 205 r888 rear tyres and have no grip issues in the dry in a straight line
Ben_Copeland
posted on 11/4/14 at 02:05 PM Reply With Quote
Z20LET here... with a VXR turbo.
272bhp and 308.8ftlb torque. Fairly easy install and much easier to get than the C20LET which is a bit long in the tooth now
Very drivable and goes like a scalded cat on speed
[Edited on 11/4/14 by Ben_Copeland]
Ben
Locost Map on Google Maps
Enter Your Details Here
loggyboy
posted on 11/4/14 at 02:58 PM Reply With Quote
Arent they largely identical just with mildly different cam profiles and management for more modern emmission vaules for the Z version?
Mistral Motorsport
Ben_Copeland
posted on 11/4/14 at 04:26 PM Reply With Quote
Bottom end is very similar. Heads kinda similar.
Z20let makes more power standard form.
Difficult to get c20let engine and parts now. Especially oem parts.
Ben
New Topic New Reply
