sky12042
posted on 29/4/14 at 03:15 PM |
Electrical problem
I'm a complete novice when it comes to electrics and I have a problem, lights, when I switch onto side lights all ok, then on dipped on the near
side light I get both high and low beam and side light goes dim, if I flick onto high beam I still get high and low with a dim side light.
Checked the bulb all ok there, no wires I can see have come loose, any idea. I'm guessing some sort of short but where do I look.
Cheers for any help
Andy.
whitestu
posted on 29/4/14 at 03:30 PM |
Sounds like a bad earth to me. Try earthing the lights directly back to the battery negative. f they work fine then the earth is your culprit.
Stu
gremlin1234
posted on 29/4/14 at 03:50 PM |
yep classic bad earth,
sky12042
posted on 29/4/14 at 04:04 PM |
Ok on checking the earth I've moved the wires around the earth and it came on correctly, even when the earth was disconnected it still worked
but if I moved the cables a little bit it went bad again, I'm going to have to undo the wiring a little to investigate.
Cheers for the help
Andy.
