Author: Subject: FS : 13" Carbon CSR Front Wheel Arches - Seconds £70 Delivered
Barkalarr
Contributor
Posts 942
Registered 14/3/12
Location Essex
Member Is Offline
Photo Archive Go!
Building: Caterham R300, Caterham Roadsport,Indy R1,Indy Zet
posted on 27/8/14 at 12:39 PM Reply With Quote
I've a pair of Carbon 13" CSR front wheel arches which have a good layup, but the trimming has gone a bit wonky so as such am selling them as seconds.
More pictures can be seen here of the trimming : I've tried to highlight the issues.
Someone with some patience will be able to make these perfect, they just need a fettle with a dremel.
£70 delivered to UK
[Edited on 27/8/14 by Barkalarr]
shindha
posted on 27/8/14 at 04:57 PM Reply With Quote
Hi what tyre width will they cover?
Barkalarr
Contributor
Posts 942
Registered 14/3/12
Location Essex
Member Is Offline
Photo Archive Go!
posted on 27/8/14 at 06:04 PM Reply With Quote
They are 220mm wide - they're spot on for a 195 and they'll be ok on a 205 (depending on the tyre).
If you're using an A048 or R888 then I wouldn't go wider than a 195.
moochofun
posted on 1/9/14 at 08:14 AM Reply With Quote
You have a PM
Sezing the moment...
Jon Ison
posted on 1/9/14 at 08:46 AM Reply With Quote
If they haven't gone I will defiantly have them no faffin monies ready to send.
Barkalarr
Contributor
Posts 942
Registered 14/3/12
Location Essex
Member Is Offline
Photo Archive Go!
posted on 1/9/14 at 09:46 AM Reply With Quote
Sorry Chaps these have gone already, however I will keep your names in the frame for any future ones we might have...
moochofun
posted on 1/9/14 at 10:44 AM Reply With Quote
Okay, no probs, thanks for the heads up.
Ta
Ross
